Engine I.D.
Not too shy to talk
From Seattle Washington USA
Hello all! =)
I just acquired an engine block and the dude I bought it from said it was a L18 from a 510 station wagon. Looking at the number stamped on the side, I am not sure that it really is an L18. Does anyone know how to look up the #'s on the block to figure out if it really is an L18? Any help is GREATLY appreciated! =)
the stamp reads...K25 4220A
Posted on: 2012/2/8 0:35
Re: Engine I.D.
That's a k series engine a future sort of evolution of l series
Posted on: 2012/2/8 0:49
Re: Engine I.D.
Not too shy to talk
Is there a way to figure out just what year it came out of/is? And if it is an equivalent of the L18?
Posted on: 2012/2/8 1:00
Engine I.D.
Not too shy to talk
Hello all! =)
Posted on: 2012/2/8 1:07
Re: Engine I.D.
From Kyoto Japan
a picture tells a thousand words.
should be stamped on the lhs of the engine on a machined area between #3 and #4 cylinders.
Posted on: 2012/2/8 1:21
guard mirrors, whitewalls.....life's almost complete.
Club Sunny Truck - REPRESENT!
Hayashi Racing
Secret Factory Japan
Re: Engine I.D.
From gold coast aus
whats the engine number on block
Posted on: 2012/2/8 1:37
Re: Engine I.D.
To clarify, if it is an L18, it will be stamped "L18".
K25, etc is probably not stamped but cast -- is that what you see?
Posted on: 2012/2/8 1:56
Re: Engine I.D.
Not too shy to talk
I only have the bare block and the only numbers I can find on it are the K25 4220A and yes...they are cast not stamped. Would there be more numbers somewhere else I am missing???
Posted on: 2012/2/8 2:15
Re: Engine I.D.
The cast numbers are casting numbers. They don't tell what size the engine is. The engine ID will be stamped.
As previously stated it "should be stamped on the lhs of the engine on a machined area between #3 and #4 cylinders". Or under 2&3 (center of engine block).
Have you looked there? Under the grease?
Posted on: 2012/2/8 2:37
Re: Engine I.D.
L series aren't greasy, just well lubed
Posted on: 2012/2/8 2:42
