Re: Is this a starter prob
From Sydney, Australia
yeah clicks mean worn out or dirty solenoid. This can be caused also by a faulty ignition switch or wiring.
Pull the high tension lead from the coil that goes to the distributor to stop the engine starting. Use a wire from the starter spade terminal, and when you are away from the motor, push the jumper wire to the positive terminal of the battery...it should crank careful of too much sparks..
If it works every time, then it's the wiring or ignition switch. If it still clicks..it's the solenoid.
Posted on: 2006/2/20 12:08
Subject Poster Date
     Is this a starter prob Widget 2006/2/20 8:40
       Re: Is this a starter prob Ronald 2006/2/20 9:38
         Re: Is this a starter prob Widget 2006/2/20 10:01
           Re: Is this a starter prob dattodude 2006/2/20 12:08
             Re: Is this a starter prob Dodgeman 2006/2/20 14:04
               Re: Is this a starter prob Widget 2006/2/21 10:10
