a15 engine
Not too shy to talk
From Devonport, TAS
hey, im looking at buying an A15 engine to transplant into my 120Y wagon. what car did the A15 come out in? and where would i be able to get a motor from?
Posted on: 2006/2/18 15:45
Re: a15 engine
From Christchurch NZ
A15's are found in nissan c20 vannettes, and some square headlight sunnys.
It is advised if you transplant a van motor in, to reuse the original flywheel.
Posted on: 2006/2/18 21:07
Forced Induction!
Re: a15 engine
Not too shy to talk
From Devonport, TAS
when you say reuse the original flywheel im assuming you mean the one off the A15 and not the A12?
Posted on: 2006/2/19 12:32
Re: a15 engine
From SE Melbourne
Nope other way around - I'm pretty sure he means re-use your A12 flywheel because it is lighter allowing the engine to rev more freely.
Posted on: 2006/2/19 12:50
Mildman, Datsunless
Re: a15 engine
Not too shy to talk
From Devonport, TAS
oh yep. thanks for the help. any wreckers should be able to help me track down an A15 motor right? tell me im not wasting my time, cos i've heard the L series engines bolt straight into the 120y
Posted on: 2006/2/19 12:52
Re: a15 engine
Maybee you should stop listening to people that don't have a clue.
The L series will not 'bolt straight in' but can be installed with less difficulty than many other engines.
Good luck with the A15, it's a good choice.
Posted on: 2006/2/19 13:23
Love your Datsun.
Treat it well.
Re: a15 engine
From SE Melbourne
Where are you from by the way - I assume Australia, but who knows....
Posted on: 2006/2/19 13:35
Mildman, Datsunless
Re: a15 engine
From Launceston, Tasmania
Sunny wagons, and SGL vanettes.
Posted on: 2006/2/21 10:29
Re: a15 engine
From Townsville, Qld
heres some food for thought. Was the A15 tuned differently in its application? say the vanette tune be aimed even lower than the sunny
Posted on: 2006/2/21 12:34
Re: a15 engine
From SE Melbourne
A good question littledarkone....
I assume the only difference would be the carby and maybe the dizzy between the vanette and the sunny.
I suppose the exhaust manifold might be different too - as I understand that the design of the exhaust manifold is generally optimised for a particular rpm.
The Vanette would surely be expected to make peak torque as a low rpm, the sunny maybe was making peak torque at a higher rpm.
Posted on: 2006/2/22 0:59
Mildman, Datsunless
