LOOKING FOR 3 JATCO 3N71B AUTOMATIC TRANSMISSIONS TO FIT DATSUN 1200 1400 1500
Not too shy to talk
From perth western australia
The box's I'm after are labeled as "Japan Automatic Transmission Co"
known as JATCO but not labeled as such.
There is usually an id tag screwed to the neutral start switch.
The model I need is a 3N71B. which is cast in the L/H side of the box.
There is a 3N71A which was the earlier model but these have inbuilt problems, so no go.
As well as the box's and converter's I will need the flex plates and the crankshaft spacers.
(only fitted to the auto's and fits between the crank and the flex plate) and if
possible all mounting bolts.
REGARDS PETER serpy1@bigpond.com
PICK UP MELBOURNE SYDNEY AND PERTH IM GOING TO SYDNEY MELBOURNE IN MARCH
STILL LOOKING GUYS
Posted on: 2006/2/18 7:14
Re: LOOKING FOR 3 JATCO 3N71B AUTOMATIC TRANSMISSIONS TO FIT DATSUN 1200 1400 1500
Not too shy to talk
STILL LOOKING GUYS
Posted on: 2006/2/19 13:37
From California
got a nice one here, but you're over there
what are these for, african taxis?
Posted on: 2006/2/19 22:11
Not too shy to talk
STILL ON THE HUNT FOR 120Y AUTOMATICS GUYS & GALS
Posted on: 2006/2/21 17:39
Not too shy to talk
TO PUT BEHIND DATSUN MOTORS I HAVE IN CARS THAT I OWN I HAVE A BAD LEFT LEG VERY HARD TO USE CLUTCHES NOW Quote:
Posted on: 2006/2/21 17:43
What, if anything, do you know about the 4N71 series of trans?
Do they share anything in common with the three speed & are they small enough to use in a small Datsun.
A four speed auto with improved A15 would make a very pleasant ride in something like a 1200.
Posted on: 2006/2/21 20:24
Love your Datsun.
Treat it well.
Not too shy to talk
Hi i know nothing on the 4N71 and cant find any info on it ,,what vechicle did it come out of ,,my thoughts are that it would be to big in size and very heavey ,, ive been told by a couple of tranny repair shops that the jatco 3n71b is bullet prove and have been used in big horse power engines with no problems
Posted on: 2006/2/22 2:41
Not too shy to talk
1 down 2 go guys and gals
Posted on: 2006/2/24 13:50
