Stanza struts into Early 120y.....Who has done it?
Heyyas....I am fitting the stanza struts into my 120 and I have one drama......the bolt holes of the steering knuckles of the 120 dont line up with the stanza struts...they are a couple of mm out each side......
Do the stanza knuckles fit the 120 ball joints or what has to be done to make em fit?
Posted on: 2006/2/25 5:52
Re: Stanza struts into Early 120y.....Who has done it?
From Brisbane, Australia
The later model 120Y and Sunny ran bigger diameter strut tubes. Have a look at them.
May have to change the lower ball joint also.
Is it not possible to put the stanza lower control arm in?
Posted on: 2006/2/25 6:09
From Townsville, Qld
120y
if you want to do a little bit of grinding. Otherwise use the 120y strut tops, abliet keeping the ride hieght up. I haven't put the Stanza arms in but I have it on good authority that they should fit straight up
Posted on: 2006/2/26 2:56
The tops are not a problem, it is the base of the strut where it bolts to the knuckle.
Posted on: 2006/2/26 4:38
Ah
righto. Never had a problem with that cos my struts came with that part too and they bolt right up. I'll go to the shed and check out the bolt spacing for both pieces for you mate
Posted on: 2006/2/27 2:26
From Stray-ya
You need the stanza steering arms- they are different to all of the 1200/120y. bolt spacing is different, length is different, and I'm pretty sure the ball joint is different too. on the bright side the tie rods will match up
edit: this may be useful
http://jaw.iinet.net.au/cars/120y/stanzastruts.html
Posted on: 2006/2/27 6:00
Awesome link.....thanks for that....
Looks like a trip to pickapart is in order!
Posted on: 2006/2/27 12:20
