Re: Wanted 1200 coupe diff
Do you need just the differential, or the whole rear axle assembly?
The differential from any sedan is the same & can be used in your axle housing, ditto for the axle shafts & brakes, but you will need the correct coupe rear wheel cylinders [different bore size]
Hope that this is of some help.
Posted on: 2006/2/27 21:47
Love your Datsun.
Treat it well.
Subject Poster Date
     Wanted 1200 coupe diff Retal052 2006/2/27 13:45
       Re: Wanted 1200 coupe diff Dodgeman 2006/2/27 21:47
         Re: Wanted 1200 coupe diff Retal052 2006/2/28 11:59
