Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Wing Windows - How to make quiet?
Posted on: 2005/11/12 18:50
The front door windows on my 1200 make a lot of wind noise.
Will new rubber seals fix this problem? Or just make it a bit quieter? Or have no effect at all?
#2
Re: Wing Windows - How to make quiet?
ang94541
Posted on: 2005/11/12 20:01
The roll up or the vent? or all of the above?
I hope new seals do something causeI bought new seals for the front vent windows but I still haven't intalled them.
#3
Posted on: 2005/11/12 21:40
The vent windows (triangular wing windows).
I cannot say if the rollup windows make noise, because the vent windows are sooooo loud. Wind noise, howl, whistle, buffeting noises ... They squeal if I close them, and get lower pitched but louder buffeting if I crack them open.
#4
sidedraught
Posted on: 2005/11/12 22:27
I find that if I fold up a piece of paper to about an 1/8 of an inch and put it behind the catch it holds it tight enough to stop it whistling. My rubbers are in pretty good shape.
#5
Posted on: 2006/3/5 9:25
OK, I got new rubber seals for the wing windows (front ventilator glass) and put the driver's side on today. It took about one hour. And indeed, that window is now quiet, at least at 35 mph, but the passenger side is still whistling. I can't wait to fit the other one.
About $17 USD each from the Nissan dealer.
#6
pager
Posted on: 2006/3/5 11:46
silastic. its the way to go an a added bounse you carnt open them an it looks ultra cool.
lol
#7
Posted on: 2006/3/5 18:14
Silastic. I had to look that one up. It is silicone rubber sealant.
I thought of that, but was more thinking of taping (using clear tape) the body to the glass, and also removing the drip rail from the roof. It might quiet the wind noise considerably.
#8
Posted on: 2006/3/5 22:27
silastic works a treat, and if you put painters tape on the glass it wont bond to it after it dries so you can still open it as usual
#9
rb20
Posted on: 2006/3/5 23:11
use a 10cent coin behind the catch hold that works also
#10
dattodude
Posted on: 2006/3/6 0:52
10c coin trick!!
I have used that trick on many occasions..good call! There's always 10c in the ashtray. An equivalent would be a 5c nickel in US currency. You can view topic.
