« 1 (2) 3 »
Re: Wide body datto 1000 fastback coupe
From Sydney Australia
Hey Justin,
I was wondering what you wanted to build the coupe for? is it going to be a circuit racer, or a street one? here are some pictures of mine. my 1000 coupe
What engine has yours currently got in it? Ive got a feeling that to put a CA18 in you need a modified 1200 front end... can someone confirm that?
cheers, Ian
Posted on: 2006/3/6 8:43
From Stray-ya
Not sure about track width though off the donor vehicle my understanding was it could only be 25mm no matter what.
Phunkdoctaspok & I discussed this in the stanza brake upgrade thread. It depends if your local DOT has fallen into line with the national code yet. In WA it is "not more than 25mm" you may be ok where you are.
Page 39/LS72:
"Where non-original axle or suspension cross-member components are fitted, the offset of the wheel in relation to the axle or hub assembly used, must not be increased by more than 12.5mm each side of the vehicle based on the specifications of the axle components used. If an axle assembly is shortened then the track width limit is taken as the axle manufacturers original track dimension, less the amount the assembly has been narrowed, plus 25mm;
Posted on: 2006/3/6 9:23
From Newcastle (NSW)
Well...I've had time to cool down now after hearing about your plans to widen your kb10 body!
I'm still of the opinion that the original setup is brilliant, simple and easy to maintain. However, if your dead-set on widening it, then good luck to you. I've never heard of the vanette front suspension swap. What section is wider? Is it then the arms, the cross member or both. The spring must be. Nowing datsun, they probably used many shared components!
The panel work shouldn't add too much I guess. The diff, motor and gearbox will add a quite a bit though. If your doing any sort of hill climb or circuit work then a steel cage will be needed.
Posted on: 2006/3/6 9:41
Grunterhunter wrote:
Either way the clause implies a crossmember change, not just putting different suspension arms, hubs etc onto the same crossmember, so the vanette option may be a good way to go.
Like I said;
I recommend you read the guidelines clearly.
A stub axle is an axle, is it not?
Therefore if you change the stub axle the wheel track limit is like I previously stated.
A hub is not and axle, it is fitted to an axle.
Example - Dattoman_1000's brake swap. Although good as it is, it doesnt meet the DOT requirements for increased wheel track.
It is to do with the loads applied to the components. If you increase the wheel track by just hubs or wheels, it will place more load on the bearings and balljoints. But if you increase wheel track with another axle from a bigger heavier vehicle, the axle components will be within there tested load handleing range.
Its not that hard to understand if you read it for what it says. No guidelines are set on visual ergonomics. They are all set based on engineering principals.
I do believe there is a pic located in the photo album somewhere, of a 1000 engine bay showing its had 1200 strut towers fitted.
Posted on: 2006/3/6 10:27
From sydney
If you have the ability to do the widening of the front and rear guards like say an old Audi Quattro I think it would look fantastic, the wide edge right down the side at top of the door height really lends itself to this.
I have often thought about it but its beyond my metal working capabilities.
Those brakes are probably overkill,I have always gone the smaller lighter faster route, but if its getting a CA18 transplant it should have plenty of power to spare for whatever weight you care to add.
Its everyones dream to build the ultimate Datsun, I say go get em ,I cant wait to see it.
Posted on: 2006/3/6 10:57
Quite a regular
From Southside of Brisbane
For those who know of Mark Ashford "Ashford racing" who owns the 7 second nissan s14 drag car with the FJ20 in it well he is going to help me build the motor he also has flowed bens heads I belive for his a15 motor. Mark said he can probably get me 300Kw at the wheels so you can under stand why I want to change the rear diff and possibly go to a vanette front I have found that the tie rod ends on the vannette front are the same model as the
1600's so it might be a lot stronger front end but I have to try and find vanette in brisbane I can measure up which I haven't had much luck in. I was also told on Saturday that a friend of mine thinks that the vanette has fibreglass leaf springs which are lighter also and have better handling characteristics. Just need to find out widths etc of the vanette front end. Anyway I will be happy to keep everyone up to date once the project starts early next month hopefully.
As for the roll cage well it has to be steel for roadworthy in QLD they also can only be bolt in cages not welded. Last cage I built in a cams approved/ QLD transport approved car we made a large plate on the floor panels which the cage was bolted to and then there was stitch welds around the twin 8mm plates which helped hold them together we got away with doing it this way because the stitched tack welds are only to hold the cage while it was bolted and could easily be ground off to remove the cage. Obviously all the stitch welds are a lot stonger than the bolts through the plates though :)
the cage I am looking at putting in it will be a 10 or 12 point cage so the body will not move and rego will be 2 seater only as you will never be able to get to the back seats. the mandatory side intrusion bars will be made removable for department of transport but will be used at any motorkana, hill climb, drifting or drag racing event. roll cage will also go to major suspension parts (shocks) or as close as legal and practical I want to build this as a all round car.
The reason I want to make it wider is that I have been told they are very unstable and have a good oportunity at rolling, I do not want to build a car that will want to roll when I put it sideways at 100+ clicks around a corner. Especially if I am sinking $20K+ in it
I figure its a rare car and I want people to see it and say that is insane :)
So if anyone has a vannette out there and a tape measure :) can I have some dimensions
As for wheel sizing I want low profile tires to stop some body roll and I figure a 15" tyre on the back you would see rim only and no tyre in a 12" guard which always looks tough on a small car, plus the bigger the tyre the more rubber on the road.
Posted on: 2006/3/6 14:50
Lead
From Portugal
-i dont agree with this mod, if you want a larger car, why you dont buy another model? a larger model.
And to all who thinks that this is just a car.
This site was created to all who like datsuns, not for who like to destroy them.
And if after all that transformations , the car doesnt approve? what to do with it ? TRASH with it????
This is not the datsun1200.com ideal.
But this is just my opinion.
Am
Posted on: 2006/3/6 19:49
Exactly. For this reason we build our cars the way we ourselves like them.
Your car is not my car. So you should not build it for me. We may like the same style but you should be building your car so you enjoy it regardless of what I think.
Exactly how many datsuns on this site are actually stock, just the way Nissan made them?
Where do you draw the line to say a body mod is any different to an engine change?
Your opinion is respected, But which one is it? Datsun1200.com ideal or Your own opinion?
Posted on: 2006/3/6 22:36
From Portugal
Steve, i understand what your are saying, but in my opinion, we should transform and improve our little toys, but with transformations that we can go back again.
This is like tatoos, do you have any? you have to think very well about the tattoo you gonna do, or youl regret some time later.
My datsun is part of me.
Or perhaps i do too mutch value to cars.
Posted on: 2006/3/7 0:43
Its cool to feel the way you do.
But a body mod and a disliked tattoo can both be fixed with an angle grinder.
If we can modify a panel, Why can it not be restored.
A rusted panel can be cut and restored to look original, Why cant a modified panel?
It might take time and skill, but if you love the datsun you will do it.
Having said that - if you dont have the confidence or determination - maybe think hard about it. I personally have the thought that with the things I do, If I stuff them up, I simply learn to repair it. If you scared to go in the water and never attempt to - you never gonna know what its like.
Posted on: 2006/3/7 2:41
« 1 (2) 3 »
