Gearbox question
From west sydney
This is some of the main shafts I have, I'm trying to make up a good w56 120y box, is there a way of cleaning up the main shaft where the pilot bearing runs, the good one is out of a w60 sunny box , & is a different length, the other 2 are a bit stuffed can the better of the 2 be polished or can a speedy sleave or something else be done.
Thanks Trev
Posted on: 2006/3/2 6:38
nothin revs like a GX
Re: Gearbox question
From west sydney
aa
Posted on: 2006/3/7 3:03
From Townsville, Qld
Next time use that often abused word "Bump". Now about those thingies, try it out with the worst one but not too much. Is that scouring look on them actually raised?
Posted on: 2006/3/7 3:59
A speedy sleeve sounds do-able. Check with your local machine shop, they should be able to fix it.
Posted on: 2006/3/7 4:02
From Canberra
If its the centre shaft in the pic that you are refering too then a quick polish in a lathe should be enough to do the job in a standard box. Measure the dia on a good part of the shaft first then polish then remeasure to make sure you dont remove too much material. Simple
Posted on: 2006/3/7 5:15
From Bris-Vegas
If you go for a speedy sleeve, you're looking at bearings to match different sized sleeved shaft + they aren't always the strongest option.
I's suggest machining back, spray welding & grinding.
More pricey, but more longevity / strength.
Posted on: 2006/3/7 7:54
CA18DET '74 1200 ute project
From west sydney
I took the shaft on the right to a mates place & polished it on a buff wheel, it took .01 of a mm off, so i'll give that ago.
Trev
Posted on: 2006/3/7 22:39
From Bris-Vegas
Just keep an eye (or ear) on it.
If the case hardening's damaged, it'll just be a matter of time before it starts to disintegrate.
You'll know cause it'll be noisy as hell.
Posted on: 2006/3/7 23:31
From west sydney
Thanks, it's just a 4 speed so no big deal if it stuffs up, i'm practicing for when I do the 5 speed.
A mate said he got the gearbox factory to machine the shaft down & use an under size bearing, but wouldn't they have to reharden it.
Trev
Posted on: 2006/3/7 23:58
From Bris-Vegas
Yes, as case hardening is typically only about .25mm thick.
There are places that can do this with either cynanide salts or nitriding, but by far the easiest is the spray welding method I mentioned earlier.
Posted on: 2006/3/8 4:05
