minor oop..its
www.paeco.com As for hoping up the A14 , my first question is do you have to smog the car?? If so be carefull as the 9000 RPM cam won't pass.
Next:be advised that these cams that let the motor rev to 9K usaully come on at 5K and without a close ratio gearbox you will hate the car. Full race A14's will pump out 180 HP or so but need servicing every 6-7 hours.
For a streetable car I would go with the GX Cam , header , 2 inch exhaust , the race valves which are 2mm bigger I believe , dual valve springs (lets it rev to 8K) and a weber 32/36. This should get you about 15-20 more horsepower maybe a little more if you have someone who can clean up the ports.
Remember the stock 210 gearbox has a huge jump in ratios between 2 and 3rd and if you build a peaky motor it will take the fun out of it for street use , not to mention the brakes on a B210 can best be described as fair.
Tom
