msd/resister?? needed?
Quite a regular
From hilo,hi
I have a 620 pick-up...i'm putting msd box and coil..do i need to keep the stock resistor?is there anyway i could bypass it and will it make a diff...thanks
Posted on: 2006/3/8 4:47
Re: msd/resister?? needed?
From sacramento california
when your running msd (muliple spark discharge) with a high voltage coil, depending on what distributer you have determines what resistor you need. it is just a whit chalky thing with two terminals on it. any auto parts store should have it. it will run horribly without it though. so, yes it is a must
Posted on: 2006/3/8 12:25
From Sydney, Australia
Depends what coil you have.
Some coils can handle 12V all the time..
The resistor-equipped ones can't. They can only handle 12V during start cranking.
Removing the resistor, will make the coil go into meltdown on a long drive.
Get the specs on the coil that you've bought with the MSD box. That will tell you whether it needs a ballast resistor or not.
Posted on: 2006/3/8 13:05
From Castro Valley,CA USA
Here are the instructions
6series.pdf
from MSD
There are several wire diagrams in there. It should make your installation easy.
Posted on: 2006/3/8 19:49
Not too shy to talk
From Guatemala, Central America.
Please show us some pics when you finish the installation and tell us how it works.
Posted on: 2006/3/9 23:11
Quite a regular
From hilo,hi
thanks guys..i just thought that leaving the resister out will increase spark...well i'll stick to the resister.
Posted on: 2006/3/10 6:37
Putting the resistor if its not required, is abit silly. Whether you have points or elctronic pickup inside your dissy makes no difference. The dissy is just a trigger for the MSD ignition module.
Like Dattodude wrote - it comes down to what coil you have. This then determines if the resistor is required. The coil is the one and only thing that determines this.
Posted on: 2006/3/10 6:44
Quite a regular
From hilo,hi
well i'm useing the msd blaster coil 2..will i need one???
Posted on: 2006/3/19 6:45
From Tracy ,Ca
when hooking up coil. coil is hooked up directly to msd unit no resister between controller and coil you can leave the resister in line that is now hooked up to the control unit to supply ign power feed to turn controller on. it no longer provides power to the coil. the coil now recieves its power thru the controller from the feed to the battery. the resister reduced voltage across the points to keep them from burning out. check the msd wiring guide.
I ran a msd unit on my race car for 15 years no resister with bocsh coil, before converting to electromotive cranktrigger
Posted on: 2006/3/19 7:31
Quite a regular
From hilo,hi
so i can just bypass and connect the two wires without the resister in between??and will it be o.k...once again this is a electronic distribiter
Posted on: 2006/3/20 5:21
