ID this engine
From Vancouver BC Canada
I just aquired another b210 coupe yesterday, and yippee, its got a 5 speed. Came with many parts including 3 grilles, 4 bumpers, 4 speed box, 5 speed box, lots o' stuff.
Anyways the guy said he replaced the engine. I am trying to figure out the head castings (don't you love this question?).
The valve cover says "datsun" and has a steel vacuum rail on the right that bolts on the cover.
The casting reads
#13 H7240
The block however has a boring H72 cast on it, so nothing special there.
Posted on: 2006/3/13 3:41
If at first you don't succeed, lower your standards.
Keith (Mac-Datty)
Re: ID this engine
From Sydney, Australia
B210 H50 to H81
As it says datsun, must be a '73 -> '76 model, after which it says nissan, but the cover could have been switched for an earlier one, so hard to tell.
Looks like an 210 - A12 head.
It's all B210..Probably pre-horrible pollution stuff, like was fitted in 1976.
Chris
Posted on: 2006/3/13 4:05
Re: ID this engine
it has air injection
Posted on: 2006/3/13 6:04
Keith (Mac-Datty)
Re: ID this engine
From Quairading, Western Australia
could it be an A13?
on the right hand side of the engine, between the dizzy, (distributor) and the back of the engine and the back of the engine there should be a rectangular (but machined) flat spot on the block it should read "A13" or "A14"
it will probably be covered in oil but clean away the grime; the engine will tell you it's secrets!...
Posted on: 2006/3/13 6:36
Re: ID this engine
From sacramento california
i ahev a b210 sdoor sedan and my valve cover says nissan, however somwhere on there it says h72. it might be and A13 or like mine an a-14
Posted on: 2006/3/13 9:28
Re: ID this engine
Casper, that is the answer I was looking for.
Just kidding.
You used many words to say nothing.
I have a coupe not a sdoor sedan.
Posted on: 2006/3/14 3:07
Keith (Mac-Datty)
Re: ID this engine
The block is tagged a14.
Guess the next thing to do is to pull the thermostat housing and see if there is actually an air port behind it, as the air check is blocked off.
Posted on: 2006/3/14 4:10
Keith (Mac-Datty)
Re: ID this engine
From western nc
not too sure bout yours but the vacuum rail is steel an on the right on my a15. could just be a frankenstein with assorted atrocities.
Posted on: 2006/3/14 6:35
"from the forest itself comes the handle for the axe..." -Matisyahu
