#1 a14 turbo
fat_dat Posted on: 2006/3/13 10:20
what kind of power figures could you expect out of a a14 turbo? or would i be better off saving for the CA conversion
#2 Re: a14 turbo
casper17000 Posted on: 2006/3/13 10:35
naturaly you will get more performance from the conversion. however if you ipgrade the internals of the a-14(rods, pistons?, cam. then the turbo will have great succes. still not as much as the conversion still. but it will RUN
#3 Re: a14 turbo
fat_dat Posted on: 2006/3/13 10:37
that sounds alright, i just wanna check out what's going to be the most fun for the dollars, it could end up being a better option to just save my ass off for the CA and then it'll be a rocket...i'll see i suppose
#4 Re: a14 turbo
B210sleeper Posted on: 2006/3/13 18:32
An A series with a proper turbo will go fast and still handle.
If all you care is 1/4 miles in a straight line or just really like to feel the G"s then get a CA or an SR.
A series engines get a bad reputation for being slugs because nobody ever gives them a good work over.
#5 Re: a14 turbo
sidedraught Posted on: 2006/3/13 21:44
I believe guys are getting about 200HP from turboed A series.
#6 Re: a14 turbo
fat_dat Posted on: 2006/3/14 0:24
correct me if i'm wrong, but thats more power than a stock ca in a datto, going off a mate of mines
#7 Re: a14 turbo
Cable_Tie Posted on: 2006/3/14 0:40
Yep, but a moded 200HP CA is hardly pushing the limit. . .
#8 Re: a14 turbo
fat_dat Posted on: 2006/3/14 0:45
good point, it would be interesting to see which would be cheaper, i was reading the thread "stupid noob and his CA project" and mate it sounds pretty $$$ for the CA project, i'm saving at the moment but does anyone have any suggestions for something a little more interesting? i wouldn't mind a rotor in there
#9 Re: a14 turbo
sidedraught Posted on: 2006/3/14 0:47
And you really would be pushing the little A motor to its limits at that hp.
The turboed A series would be cheaper, however I would recommend going down the tried and true path of working an A series, twin carbs,etc, and you will end up with something that goes fast is reliable and you dont need to jump through too many engineering hoops to get it registered.
#10 Re: a14 turbo
fat_dat Posted on: 2006/3/14 0:51
yeh maybe i should steer clear of that, see the thing is, there are many conversions i'd love to do to my ute...start with a a14 turbo, then a ca, then a fj and then take it off the road and make a full on race car....sounds good eh but the bank will only allow for one and i need a car to drive aswell ... if anyones got a good suggestion for something to aim for that'd be pretty helpfull
