A12 motor
Quite a regular
Im thinking of rebuilding the a12 for my 12oo ute or should i go bigger and what type fits easy enough?????
Posted on: 2006/3/20 9:48
Re: A12 motor
From Wamboin near ACT(canberra)
widely talked about topic. do a search. cheapest and easiest convo is the a14 or a15. more power for a good price
Posted on: 2006/3/20 11:04
Re: A12 motor
The ease of converting to the larger A14/15 engines will be dependant on when your ute was built. If built up to '73, it will be relatively easy, but if it is from '74 onward, it will be quite easy.
Posted on: 2006/3/20 16:14
Love your Datsun.
Treat it well.
Re: A12 motor
From Chifley, Sydney
What about a a14/a15 into a 1000 ute?
Is it harder to do then a 1200 ute and is it the same as putting it in a 1200?
Posted on: 2006/3/21 2:44
Re: A12 motor
There is a little more work to fit the A14/15 in the 1000 than in an early 1200 ute, but as engine swaps go, it's still pretty much straightfoward.
If you use the 1000 gearbox, you will need to shorten the spiggot part of the gearbox input shaft or else it will bottom out in the crankshaft & prevent the gearbox from bolting up to the engine. There are some minor issues with the clutch release bearing too [use a 1200 assembly] but nothing too dramatic.
Posted on: 2006/3/21 3:34
Love your Datsun.
Treat it well.
Re: A12 motor
I will be buying a celica 5speed for it.
Will i find more info on this in the seach bar? I had a quick look but didn't see much.
We should put it in the Tech section along with the a14/a15 1200 conversion.
Cheers
Ryan
Posted on: 2006/3/22 6:08
Re: A12 motor
Search for:Quote:
toyota 5-speed
It's in the Tech Section
Posted on: 2006/3/22 6:44
Re: A12 motor
Sorry not the box
The a14/a15 into a 1000
Ryan
Posted on: 2006/3/22 7:53
Re: A12 motor
From sydney
Its pretty much the same especially if you use the 1200 box so probably doesnt need its own section.
Posted on: 2006/3/22 8:28
