Re: flywheel bolts coming loose. a15/120why
From Warburton vic
yes use lock tight.
Tighten them to manufactures specs & you wont have a problem. If it happens again dowel the crank & fly wheel
Coops
Posted on: 2006/3/21 11:06
Subject Poster Date
     flywheel bolts coming loose. a15/120why nate 2006/3/21 8:38
       Re: flywheel bolts coming loose. a15/120why sidedraught 2006/3/21 9:26
         Re: flywheel bolts coming loose. a15/120why casper17000 2006/3/21 9:34
           Re: flywheel bolts coming loose. a15/120why COUP1200 2006/3/21 11:06
             Re: flywheel bolts coming loose. a15/120why dattoman_1000 2006/3/21 11:18
               Re: flywheel bolts coming loose. a15/120why dattodude 2006/3/21 13:56
