after some help on jet sizes
From south coast nsw
just installed a pair of 40mm dellortos,just wanna get an idea on wat size jets people are running?im running an a12 ?
Posted on: 2006/3/25 7:59
Re: after some help on jet sizes
anyone?
Posted on: 2006/3/29 13:18
From Sydney Australia
Have a search on google try "tuning dellorto carburetta" or something there is a graph that allows you to work out the right venturi size for a certain size engine and engine rpm of redline or max power then once you have the right venturi you can use a formula to work out basic idol jets, main jets, air correctors and emulsion tubes these wont be perfect but your car will run with abit of fiddling enough to work out the right components.
I used the graph when i had a dellorto but i cant remember the jet sizes of the top of my head.
Posted on: 2006/3/29 13:53
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
From Bay of Plenty
have the jets & tubes got numbers on them that are in it i have some sss specs
Posted on: 2006/3/29 20:45
From Sydney
for 1200cc @ 6200 RPM
try around:
27mm chokes
105 - 110 mains
160 - 175 airs
35 - 45 idles
30 - 35 pump
remember that the idle jet will have the most influence as most street driving is on partial throttle movements. idle and progression circuits are primarily metered from the idle jets.
Here is a pic of the relationship of the fuel circuits
Another consideration is the engine compression and the type of Cam shaft installed.
Also make sure that both carbs are balanced and synced. If you here popping or backfiring back through the carb [one barrel or more], this usually indicates that the mixture is too lean. There is plenty of info on the web for tuning sidedraught carbs on the web.
cheers
Benny
Posted on: 2006/3/29 22:54
