Do a15 go 'straight into' 1200 utes
As i am just about to purchase an a15 for my 1200 ute, do they or dont they fit in with no mods? At the moment i have an a12 and have the option of buying a crossmember and engine mounts with the engine, do i need these?
cheers
Posted on: 2006/3/31 6:34
Re: Do a15 go 'straight into' 1200 utes
From Townsville, Qld
Yes. I had a look around and read somewhere in here that the the 74 and up A series have a lot more in common with the A14\15 so swaping is a little easier. If you're going to do this might as well find out everthing I cant tell you, read some of the old posts around and ask the questions. We're here to help (well I'm not ) so yeah you should grab that crossmember if you like and mabey some black paint too, makes it harder to find fault when getting rego'd
Posted on: 2006/3/31 8:26
From sydney
I reckon an early model ute might need a tiny bit of modding, (nothing that should take more than 1/2 hour) and a later model it should fit no problem.
Posted on: 2006/3/31 8:27
See How to fit Datsun A14 & A15 Engines.
It depends on which engine your ute has now: 1971-73 engine, or 1974 and newer engine.
There's also considerations of exhaust, wiring and diff (for early utes).
Posted on: 2006/3/31 8:35
any thing fits in a 1200 depends on your budget
Posted on: 2006/3/31 10:10
