hi folks im new to the a series datsuns and ive just got a hold of a 76 1200 ute and spare sedan.
after some searching ive found some similarities to the a14/a15 and the e15 bottom ends,and it seems pretty possible to use a mix of the bottom ends for a pretty tough forced induction setup.
the e15 crank is said to be able to be machined to fit a series block,im wondering if it can be made to fit the a series cam chain drive or if it can only keep the belt drive and run the e15t head/cam etc
it seems the short rods and strong crank and dished 76mm pistons would make a good start for a low comp ratio.
or maybe just e15t pistons with a machined crown would work in the standard a15 bottom end?
otherwise its probably easier to just bolt the e15t motor in complete,with the dissy mod and bellhousing bolt modded?
i know it would be easier to ca or sr the ute,but id rather something different and the e15t motors are sitting at a mates place.
any info appreciated thanks S.F
