« 1 (2) 3 »
Re: Lobster
From Canberra, Australia
Am I right that the driver side (Right side) of the diff is a tiny bit shorted than the passenger (left) side, so there is more chance of the wheel rubbing on the right side?
I swear it is true...
Posted on: 2002/11/22 13:39
Re: Lobster
From Melbourne, Australia
i dont think so cause i checked once and it doesnt matter what axle you put in either side because they are both the same length, so i think you are wrong
ive found my tyres touch a lot cause ive only got one shocker in the back at the moment, so the diff moves from side to side easily, makes me wonder with the sedans and their upright shocks what stops sideways movement of the diff?
Posted on: 2002/11/22 13:44
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Lobster
Hmmm yes, shock absorbers... Might get some that aren't twanged up....
Can you still buy rear coupe ones?
I remember someone telling me that you couldn't anymroe or something?
Posted on: 2002/11/22 13:52
Re: Lobster
i went through this just last week with my mechanic, we rang around asking for shocks for begginer rally car, basically:
pedders half decent ones, though would cook if driven toooo hard (experienced rally driver) $140 for two
koni, beuatiful adjustable whatever whatever, i think $240 EACH
some other mob not as good as pedder $160 for two
basically i think they take a shock which has the same length and travel requirements as a 1200 coupe and then change the rubber in the bottom to make suit 1200 pin size, this was going to cost an extra $12 for koni's but im not sure with others, anyway they had some that would fit, i could get you the code of the pedders if you like, it would probably be good for you, they are pretty stiff giving good performance but it will be a rougher ride on the road, youd never cook them on the road!
Posted on: 2002/11/22 14:03
1200 Coupe Rallycar
Re: Lobster
Yeah if you could get me the code that would be sweet. I think I remember somethign being said about kingswood or something shocks being used, but the guys really didn't know what they were talking about so I left em.... And tought em a lesson by never getting the rear shocks fixed!
Posted on: 2002/11/22 14:13
Re: Lobster
It's actually the leaf springs. The shocks have enough rubber bushing so they won't do it (coupe or sedan). The leaf spring bushings aren't supposed to move side to side much, but a little up/down and forward/back.
Posted on: 2002/11/22 22:50
Re: Lobster
mine must be pretty worn then cause my diffs "swinging like a dunny door"
Posted on: 2002/11/23 2:56
1200 Coupe Rallycar
Re: Lobster
Note: "Dunny" is a nickname for a toilet, normally an outdoor one, in a little metal shed...
Posted on: 2002/11/23 5:51
Re: Lobster
no flush, just a "long drop" or hole in the ground, old style aussie toilets, still some out in the bush
Posted on: 2002/11/23 6:00
1200 Coupe Rallycar
Re: Lobster
From Fort Worth, Texas, USA
That would be an "outhouse" here.
I think I'll also point out that "dunny" sounds an awful lot like "bunny!"
Posted on: 2002/11/23 16:02
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
« 1 (2) 3 »
