Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
mixture control
supadat47
Posted on: 2006/4/13 3:50
hey all, just had my 120y a12, fully reconitioned, and i dont know why but the lads had a little play with my carb and set the idol adjust screw up to over rev
as for the mixture control, well off, does anyone know a easy way to get the mixture back to the right point
#2
Re: mixture control
Dodgeman
Posted on: 2006/4/13 6:33
You can use a vacuum guage to set the idle mixture.
Leave the idle running just a bit faster than stock for a couple of thousand K's untill the engine starts to free up a bit. This helps to keep the fan & water pump spinning freely & this helps keep the oil spraying around inside & helps to reduce the loads on a fresh cam. [if fitted] If you get yourself a workshop manual, it will show you how to do all the adjustments properly, & in the right order.
#3
Re: mixture control
B210guy
Posted on: 2006/4/13 7:04
well, a super easy way would be to,
turn the idle up to about 1500 rpm turn mix. screw slow in til idle starts to drop turn mix. screw slow out til idle rises split the difference, should be perfect!
#4
Re: mixture control
phunkdoktaspok
Posted on: 2006/4/13 8:38
Yep just like that. Its not too hard. You will find it the right point is where it idles smoothly. I wouldnt worry about keeping the revs up. If a fresh engine has too low an oil pressure at idle speed - than something wrong. As for coolant - it can only circulate when the thermostat is open. If the engine gets hot at idle - the radiator isnt exactly good enough to keep it cool anywhere above idle. You can view topic.
