Re: What Diff to Use in a 120ySSS
nzdatman wrote:
but others are more readily available than for the 120Y (3.9:1 H145)
Point of order
The B210 [120Y] used the H150 diff in 3.9 to 1 ratio.
Only 1000's & 1200's used the H145 size as far as I can tell, although the H150 will bolt into the H145 housing using a spacer.[?] [this issue of a spacer is currently under debate]
The H150 is available in 3.7 to 1 ratio as well as 3.54 to 1.
Cossee wrote
Shame there wern't more diff options for the 120y
What more could there be? The rear end size & ratios were tailored for the car, complete with it's stock A12, A13 or A14 engine [depending on which country you bought it in] so, what else could a new car buyer want? The larger & heavier H165 series of rear ends would have been un-necessary overkill, it would have cost more, thereby eroding a sales advantage, & it would degrade ride quality, something that motoring writers would pick up on very quickly, to the detriment of sales.
I guess that's why there were not more diff options.
Posted on: 2006/4/15 2:30
Love your Datsun.
Treat it well.
Subject Poster Date
     What Diff to Use in a 120ySSS cossee 2006/3/23 11:43
       Re: What Diff to Use in a 120ySSS sidedraught 2006/3/23 11:57
       Re: What Diff to Use in a 120ySSS Dats-hot 2006/3/23 12:04
       Re: What Diff to Use in a 120ySSS ddgonzal 2006/3/23 17:52
         Re: What Diff to Use in a 120ySSS Anonymous 2006/3/24 0:11
           Re: What Diff to Use in a 120ySSS sidedraught 2006/3/24 0:16
       Re: What Diff to Use in a 120ySSS Dodgeman 2006/3/24 1:14
       Re: What Diff to Use in a 120ySSS stirlingmac 2006/3/24 1:23
         Re: What Diff to Use in a 120ySSS cossee 2006/4/13 9:59
           Re: What Diff to Use in a 120ySSS sidedraught 2006/4/13 14:38
           Re: What Diff to Use in a 120ySSS stirlingmac 2006/4/15 7:18
             Re: What Diff to Use in a 120ySSS cossee 2006/4/15 8:33
             Re: What Diff to Use in a 120ySSS Dodgeman 2006/4/15 9:24
               Re: What Diff to Use in a 120ySSS stirlingmac 2006/4/15 10:10
                 Re: What Diff to Use in a 120ySSS Dodgeman 2006/4/16 1:26
       Re: What Diff to Use in a 120ySSS nzdatman 2006/4/13 23:56
         Re: What Diff to Use in a 120ySSS Dodgeman 2006/4/15 2:30
           Re: What Diff to Use in a 120ySSS ddgonzal 2006/4/15 4:42
       Re: What Diff to Use in a 120ySSS B210guy 2006/4/14 22:21
