Drag Link
From Townsville
Hey folks,
Just had a check up done on the ute and found out i need a new drag link, No one deals these things and the only people who can supply is Nissan themselves at a cost of $514.30
Anyone have a draglink laying aound in good condition or know of where i can possibly get one without paying and arm, leg, kidney and testicle for it!
Cheers,
Geoff.
Posted on: 2006/4/24 4:43
Re: Drag Link
From Geelong, Vic
120y ones also fit in, i have one but dont know its condition as its still in a car
edit: ive also got a 1200 one that i just swapped for a 120y one, ill have a look at it tonight and get back to you
but then postage will probably be a killer
Posted on: 2006/4/24 4:47
Re: Drag Link
From Townsville
That would be great mate, as long as the bushes on the ends are ok, and i can garauntee the postage won't add upto 500 bucks!!
Cheers.
Posted on: 2006/4/24 5:00
Re: Drag Link
From Geelong, Vic
how do i check if they are ok, the one the only spins around doesnt have any sideways or up and down movement, and the other one that can move all over the place hasnt got any up and down movement
so it seems to be good, just needs a new boot and some paint
Posted on: 2006/4/24 11:06
Re: Drag Link
From Townsville
Not certain, i'll call the mob that are doing the job in the morning, shall ask them about it, i'll quote what you have just said about uppy downy movements.
Cheers.
Posted on: 2006/4/24 16:45
Re: Drag Link
From Christchurch NZ
There should be an engineering out fit near you which recondition them. Ask at a suspention shop, they should be able to steer you in the right direction.
Posted on: 2006/4/25 1:15
Forced Induction!
Re: Drag Link
The drag link (Cross Rod) used to be less than $200 from Nissan.
Steering Linkage, B110
You can have the joints "Plasti-surged" I had it done to my drag link, Good as new! Was only about $90 to do both ends!!!
ball joints wanted
How to check for play (wear) in the linkage: Steering gearbox adjustment. If the drag link is off:
- both ends should move freely in all directions (except up and down)
- the joints should have some friction, they should not 'flop around' which indicates wear
I have managed to get hold of an aftermarket [drag link]. The part number is STR412 ... made by 555.
My one (A '85 Datsun Ute) has a straight drag link with the necessary eyes on either side to mount the tierods and idler/pitman arm etc.
This new part I have has a slight bend at either end. It is the same length but a different shape. (Sway bar type shape)
That is apparently the difference: B210 drag links have a slight u-shape, but otherwise fit a B110. Reportedly ...
Posted on: 2006/4/25 2:00
Re: Drag Link
From Burbank, CA
I got a new one for a 310 (rwd) a couple years ago, somewhat expensive, maybe $150 USD.
Seems like an easy part to restore if they are hard to find.
Posted on: 2006/4/25 2:24
|||\ 81 KPB310 /|||
Re: Drag Link
From Townsville
Yeah the shop told me about that injecting method, Any body had that done? what did you think of it safety wise?
Posted on: 2006/4/25 3:26
Re: Drag Link
I have had my drag link for my 1000 plastic injection moulded... It seems to be working good, they told me that t is better than std...???
So far so good...
Posted on: 2006/4/25 7:02
