steering tie rods
From Taupo New Zealand
I'm in need of some longer steering tie rods. After lengthening my bottom arms which some may have read about, I'm running out of thread on the tie rods
the sunny ones are 170mm long, if anyone knows of any other datsun or any car with longer tie rods that would work I'd be very appreciative. Cheers.
Posted on: 2006/4/25 7:43
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
Re: steering tie rods
From Brisbane Australia
get yourself a new set of inner tie rod ends they will fit on the outside aswell and add about 30 mm a side from memory i had to go the other way when i shortend mine to fit a larger offset rim
Posted on: 2006/4/25 10:39
thanks for the reply john- you're on the money! 31mm I measured. I figured it out this afternoon after staring at the sunny steering for a while until the penny dropped!
so what exactly did you do? shorter bottom arms or different steering arms or what?
cheers.
Posted on: 2006/4/26 10:59
1970 1200 coupe A15
1978 B310 SR16VE
i have 8inch rims on the front of mine and to keep them under the gaurd more i shortened the lower control arm and moved the tops in 30 mm
Posted on: 2006/4/27 14:46
From hastings vic
HOW DID YOU MOVE TOP OF STUT.
Posted on: 2006/4/27 14:53
1200 sed, big brakes, ca18det, FUN
have a quick look at my pictures there are a couple of shots there and a installed pic to
Posted on: 2006/4/27 22:07
