best carby
From Merimbula,NSW, Australia
when i do my transmission conversion, ill probably look at getting a improved carby than my stock hitachi,
i have a fully stock a12 in a 75 b210 sedan and was wondering what cheap, easy, bolt right up carbys people would recomend, any suggestions welcome
Posted on: 2006/4/28 14:15
DATSLIFE
Re: best carby
From australia tasmania
check the tech section, it has several options. it is located at the top left of this page, then follow the links on this site.
Posted on: 2006/5/3 10:56
old skool cool...
www.shakotangarage.com
Re: best carby
32/36/webber but get it rejetted for the 1.2
Posted on: 2006/5/3 11:15
Re: best carby
ive just read the tech section on the carbs and they state:
Stock Hitachi 306
* the best fuel economy
* the best driveability and smoothness of throttle response, although properly jetted and synchronized Webers may run just as well (but take some tuning effort)
Weber DGV 32/36
The Weber DGV series downdraft carb is an excellent choice for the daily driver stock or lightly modified A-series engine. See the Tech Section article Weber 32/36 Carburetor.
Note that the Holley G180 and Holley 5200 are the same carburetor, as commonly found on Ford engines and others. These are made by Holley with a license from Weber of Italy.
* Least expensive upgrade choice
* can use stock A-series engine manifold by using a simple adapter plate
* Uses the Solex two-barrel bolt pattern
so if the stock hitachi is more fuel efficent, and has a smoother thottle responce, and you need to rejett the webber along with purchase adapter plates, is the webber much of a improvement, upgrade, and are the people with 32/36 webbers happy with their upgrades
Posted on: 2006/5/3 13:38
DATSLIFE
Re: best carby
From Burbank, CA
weber's better than stock, nearly as efficient. Tuning can be annoying, but most carbs are annoying to tune.
Posted on: 2006/5/3 17:28
|||\ 81 KPB310 /|||
