« 1 (2)
Re: gearboxs what is the difference between 56a and others?
From Canberra
Yeh thanks Dodgeman, excuse my lack of posting skills That is first & reverse you see in the extension housing.
For rally use the dogleg gearbox also has the major advantage of the first & reverse gate being inline. This allows you to more effectively remove the car from any "dry bog" situations by driving the lever up and down the gate quickly whilst droping the clutch. Much quicker than using the conventional shift pattern. I often wonder if this was a deliberate consideration when Nissan were developing their rally option boxes because its a great application of the dogleg pattern and can mean the difference between parking it for the day or finishing the event.
Posted on: 2006/5/5 9:34
so a 4 speed 1200 box is the same as a 4 speed with 56a on it? some just have a bigger clutch cable hole. is this right?
Posted on: 2006/5/5 9:39
From Burbank, CA
i thought the other reason for the dogleg was to set the gears up in a way that was stronger, kept you from downshifting into second and such.
Posted on: 2006/5/5 9:49
|||\ 81 KPB310 /|||
From Brisbane, Narangba
I thought the 60series had a stronger input shaft and slighty stronger gearset. 2nd gear is also a different ratio to the 56a.
Posted on: 2006/5/5 10:16
The standard 1200 gearbox is a 56A with the smaller hole for the clutch cable & thr 120Y box is the same thing with the larger hole.
The clutch cables are the same except for the boss that fits into the hole, so if you have a replacement box for your 1200 & the cable flops around in the box like c**k in a sock, you now know how to fix that.
Posted on: 2006/5/5 10:29
Love your Datsun.
Treat it well.
Everything about the 60-series is stronger than the 56-series. That's why it is a bigger, heavier box. Same length though so it easy to swap.
2nd gear? Even different 56 boxes have different gears, see the Tech Section article
Posted on: 2006/5/5 17:13
« 1 (2)
