#1 5 Speed Gear Box 1200 Ute A12 - Bolt In - Very Rare
BUL33T Posted on: 2006/5/6 7:15
I have a very rare 5 Speed A12 Bolt in gear box to suit a 1200 Ute For Sale.
There is no need for any modifications to be carried out to install this gear box, it is a simple bolt in exercise.
I am located in Penrith.
$600.00
Call if interested 0412 151 890
#2 Re: 5 Speed Gear Box 1200 Ute A12 - Bolt In - Very Rare
Dodgeman Posted on: 2006/5/6 7:42
Does it look like this, with external ribs, or does it have a smooth case?
If it is like this one, then it is a 56A type & there are two minor variants.
The difference is in the size of the hole where the clutch cable fits in [seen near the clutch arm boot.]
The small hole fits 1200 cables while the larger hole version [more common] is from the 120Y /B210 & the 120Y cable makes it all work in a 1200
#3 Re: 5 Speed Gear Box 1200 Ute A12 - Bolt In - Very Rare
BUL33T Posted on: 2006/5/6 11:24
No its a smooth outer case.
There is absolutely NO MODS needed.
#4 Re: 5 Speed Gear Box 1200 Ute A12 - Bolt In - Very Rare
Dodgeman Posted on: 2006/5/6 12:05
OK, so now we have established that it is very likely a 60 series gearbox.
Does it have a conventional shift pattern, like this?
1 3 5
l--l--l
2 4 R
Or does it have a dogleg shift pattern like this?
R 2 4
l--l--l
1 3 5
Since no mods are required, it must be a right drive model with cable actuated clutch.
#5 Re: 5 Speed Gear Box 1200 Ute A12 - Bolt In - Very Rare
BUL33T Posted on: 2006/5/7 1:03
It is a dogleg shift pattern, and one more time (just incase you missed it) NO MODS required.
#6 Re: 5 Speed Gear Box 1200 Ute A12 - Bolt In - Very Rare
LittleFireyOne Posted on: 2006/5/7 1:38
I think a change of colour is needed....
#7 Re: 5 Speed Gear Box 1200 Ute A12 - Bolt In - Very Rare
Ronald Posted on: 2006/5/7 10:55
pm sent
#8 Re: 5 Speed Gear Box 1200 Ute A12 - Bolt In - Very Rare
BUL33T Posted on: 2006/5/7 10:57
*****SOLD*****
