Browsing this Thread:
1 Anonymous Users
Re: Question bout spigot bushes |
From Merimbula,NSW, Australia
i got a thrust bearing in my clutch kit, is this a spigot bush
Posted on: 2006/5/7 5:50
DATSLIFE
From Newcastle (NSW)
It should be a light tap-in fit. Otherwise it would spin itself inside the crank. It should be tight in the crank and free on the gearbox inpout shaft.
Posted on: 2006/5/7 5:52
From Canberra
Quote: i got a thrust bearing in my clutch kit, is this a spigot bush lol, nah mate. another question: my celica box/a14 came with the spigot bush in the flywheel... normal?
Posted on: 2006/5/7 9:40
From Perth
Dellow supplies a spigot bush that goes in the flywheel for the T50 conversion Make sure you use it or you will have problems with the box jumping out of gears...... until finally something breaks
I don't use their bush though I use a roller bearing instead
Posted on: 2006/5/7 12:02
From Canberra
thanks dattoman_1000, does the original in the crank need to be removed, or is the input shaft shorter?
Posted on: 2006/5/7 12:06
From Perth
Shorter....... hence the need for the crankshaft one
Posted on: 2006/5/8 12:57
