#1 Torque settings needed
Suni Posted on: 2006/5/9 9:47
Have an a15 out of a vanette in my sunny!
Dont have a manual to give me torque settings.
Need ACCURATE torque specs for;
HEAD BOLTS &
ROCKER ARM SHAFT BOLTS
#2 Re: Torque settings needed
dattodude Posted on: 2006/5/9 10:25
A10 to A12 - Factory Manual
Head Bolts -> 32.5 - 36 or 39.8 ft-lb (higher rated torque was hand drawn into factory manual by Nissan Mechanic)
note: centre-distributor side head bolt is different to the others in A10/A12.
Rocker Arm Shaft Bolts -> 14.5 - 18.1 ft-lb
note: should be done outwardly, starting at the centre bracket.
Chris
#3 Re: Torque settings needed
Suni Posted on: 2006/5/9 10:55
Are these torque settings the same for an A15 motor???
All head bolts on the A15 look the same! Can anyone confirm this?
#4 Re: Torque settings needed
dattodude Posted on: 2006/5/9 11:10
We know the oil galleries from the top of the head to sump is different between the A12 and A15. I can't remember the difference as I've never owned an A15, and never needed to do anything except do oil changes for the A14 engines that I've had..
VANETTE
Vanette C120 1983 Repair Manual
A12 & A15 petrol engines
Inc SM3EC120GO & SM5RC12SAO
SM3EC12OGO ........................... $99.00
Nomad/Vanette 1986 C22
Repair Manual - includes A15, Z20S &
Z24S petrol engines
(LD28 diesel requires the LD engine
supplement)
SM6EWC22GO........................... $99.00
Nomad C22 1987 Repair Manual
A15S, Z20S, Z24S & LD20 engines
(LD20 refer to SM4ELD20GO)
SM7EWC22GO......................... $275.00
Prices in Australian Dollars
http://www.bevenyoung.com.au/
You could always buy a handbook if you are so insistant on getting it 100% right.
#5 Re: Torque settings needed
Tyrie Posted on: 2006/5/9 11:42
one of the head bolts should have a hole in it, or be thinner in the shaft, something like that, its one of the middle ones... sparkplug side? and goes into a oil gallery.
just something I noticed when finally putting the head back on my a14.
I was going to start a thread asking for valvetrain bolt torques... now I dont have to.
#6 Re: Torque settings needed
Suni Posted on: 2006/5/9 13:31
Considering that the car will sold next week, I really do not want to spend extra money, hence trying to get some specs of this website. Buyer is getting the car at a good price meaning that Im loosing enough money!
In terms of one of the head bolts being different, I will analyse it tomorrow! Im pretty sure they are all the same!
#7 Re: Torque settings needed
Mildman Posted on: 2006/5/9 13:32
Most likely has "T" on the head, whereas the rest of the head bolts like have "13" on the top of the head.
Here's some torque settings
TORQUE WRENCH SETTINGS
Cylinder head bolts . . . . . . . . . . . . . . . . . . . . . . . . . 74 Nm
Connecting rod nuts . . . . . . . . . . . . . . . . . . . . . . . . 37 Nm
Flywheel bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 88 Nm
Main bearing cap bolts . . . . . . . . . . . . . . . . . . . . . . 59 Nm
Camshaft sprocket ......................... 47 Nm
Camshaft locating plate . . . . . . . . . . . . . . . . . . . . . . 8 Nm
Sump bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Nm
Oil strainer bolts ........................... 14 Nm
Crankshaft pulley bolt . . . . . . . . . . . . . . . . . . . . . 196 Nm
Timing chain cover bolts . . . . . . . . . . . . . . . . . . . . . 7 Nm
Rocker pedestal bolts . . . . . . . . . . . . . . . . . . . . . . . 25 Nm
Valve rocker adjusting nut . . . . . . . . . . . . . . . . . . . 22 Nm
Sumpplug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 Nm
#8 Re: Torque settings needed
B210guy Posted on: 2006/5/9 18:15
A14-15 head bolts have a "13" on the top. not sure about A12s , one of them is "recessed" ,that is the center one.
#9 Re: Torque settings needed
cheater_5 Posted on: 2006/5/9 21:41
hey mildman. Are those tourque settings for a15?? or all ? or a12 ?
cheers
#10 Re: Torque settings needed
Suni Posted on: 2006/5/9 23:19
A15 head has a 12 on top of the head bolts (well mine does anyway)!
Same, are those torque settings for an a15??
