#21 Re: Loosing coolant (need HELP!) UPDATE!
Suni Posted on: 2006/5/3 14:54
Are you sure? I dont think it should splurt out like it does??
#22 Re: Loosing coolant (need HELP!) UPDATE!
B210sleeper Posted on: 2006/5/3 17:30
ok, what you are describing sounds like the radiator tubes are restricted, can you see the lower radiator hose sucking down when it starts overflowing?
#23 Re: Loosing coolant (PROBLEM SOLVED)
Suni Posted on: 2006/5/9 9:45
YIPPEEEE!
Head came off today, corroded head near number 4 cylinder! Coolant was leaking into the bore! So thats where all the coolant was going
As for the coolant splurting out of the radiator, that was the compression from cylinder 4 pushing through the corroded gap back into the cooling system.
Head is being machined, crack tested, faced etc and will be placed back on tomorrow with a new gasket!
I am doing all the work myself, surprising how simple an inexpensive it is. Go the dattos!
#24 Re: Loosing coolant (PROBLEM SOLVED)
B210guy Posted on: 2006/5/10 5:00
glad to see you got it! part of the fun I guess, and they are cheap to fix!!!
« 1 2 (3)
