A12 A14 A15 fuel consumption what are they?
From Adelaide, Australia
does anybody know what the fuel consumption per litre is of a A12 A14 A15? in stock form
Posted on: 2006/5/10 7:54
Re: A12 A14 A15 fuel consumption what are they?
not sure of exacts but over the same distance in my cars, the a15 used lees than an a12 in stock form by about $7 a week. But once added 32/36 and extractors to a15, it was a bit worse.
I figure as you dont have to rev the car as hard with an a15, it uses less petrol as all you do is ride to torque wave.
Posted on: 2006/5/10 9:39
Read all about fuel economy here: Performance Tech Section article.
Short answer: 38mpg highway
Posted on: 2006/5/10 17:24
From Burbank, CA
An A15 will easily get 30+ mpg on the highway at 80mph. You should get around 26-28 in the city even with a weber 32/36
Posted on: 2006/5/10 17:41
|||\ 81 KPB310 /|||
From Canada, B.C , Richmond
Also depends on your driving style.
Posted on: 2006/5/11 0:04
Also depends on the car.
The A12 in a Datsun 1200 only got 38mpg. A14 in B210 got 47mpg! And some engine in B310 got 50mpg!!!
Posted on: 2006/5/11 5:08
From Burbank, CA
some cars are more aerodynamic and such, that front airdam helps a lot too if you have one.
I'd think the A14 MT4 would get the best mpg, but who knows, datsuns always got good mpg when driven reasonably.
the factory mpg for the 81 210 (sunny 310 whatever ) with A15 MT5 was around 28 +/- 2 can't remember if that was city or highway, but i think city.
Posted on: 2006/5/11 5:16
|||\ 81 KPB310 /|||
The B210 fuel economy champ was the 5-speed model. From 1976-1/2 through 1978, it had the 63-series overdrive, and a raised port cylinder head -- an A14 with round-ports!
This was the 50mpg model! (correcting my above statement)
50 mpg B-210 Plus
The number one factor for Sunny fuel economy was not aerodynamics, which were all bad like every 1970s car. The #1 factor was lowering the engine revs to cut down on pumping losses in the engine.
The B310 best was only 47mpg. I don't know which engine it was we got A12A, A14 and A15 models.
Posted on: 2006/5/11 5:59
