Gasket or not?
From Huntington Beach, California
Is there a gasket that goes between the mounting surface of the intake and exhaust manifold?
I have seen a few of these, and there doesn't appear to be one.
Should I slather it with weatherstrip adhesive or liquid gasket, or just clean it and bolt it together?
Thanks again for the help!
Posted on: 2006/5/14 20:39
Re: Gasket or not?
From Burbank, CA
there might have once been an asbestos one there. Anything out of a tube not meant to be exposed to great heat would be a bad choice. maybe if theres a squeezable exhaust gasket stuff?
Posted on: 2006/5/14 21:26
|||\ 81 KPB310 /|||
Re: Gasket or not?
From bend oregon
There was a gasket in there.
Posted on: 2006/5/14 22:36
Re: Gasket or not?
From UK
Yes, there's a gasket originally (part # 14005-18000) but you should be able to seal it OK with exhaust assembly paste so lang as the surfaces are good. I've always done it that way and not had any problems.
-Ed
Posted on: 2006/5/15 1:10
Re: Gasket or not?
From SE Melbourne
In Australia its called a 'hot box' gasket.
I think there are two gaskets too! I got a photo somewhere....
Posted on: 2006/5/15 1:23
Mildman, Datsunless
Re: Gasket or not?
As always, thanks for the info.
I bought an entire engine gasket kit, and (of course) that gasket is not in the kit. I'll hit a local speed shop and see if they have some gasket material that will stand up to the heat. It doesn't look *too* difficult to make one, provided I use the proper material.
Posted on: 2006/5/15 2:10
Re: Gasket or not?
From SE Melbourne
Guess I was lucky with the gasket kit available in Australia...it came with two of them.
Permaseal I think are the company in Australia - and I think the gasket kit was a GC277.
These are the guys
http://www.aagaskets.com.au/
Posted on: 2006/5/15 6:46
Mildman, Datsunless
Re: Gasket or not?
Quite a regular
From Mira Loma Ca. USA
YES, there is a gasket, (2) and a definite must!
I personally have never used anything but factory gaskets , so not sure if you can get away with some type of sealant, but hey, it's a DATSUN! and if the surfaces are good and flat, Y not?
Posted on: 2006/5/15 22:03
Re: Gasket or not?
From Burbank, CA
without the gasket it must be like the EGR from hell. well not quite that bad, but probably noisy and having a bit of a leak.
Posted on: 2006/5/15 22:26
|||\ 81 KPB310 /|||
Re: Gasket or not?
One of the reasons I pulled the engine is to fix the oil leaks and fix the exhaust leak that was coming from that joint. (It was pretty loud and drove me crazy)
I found a sheet of proper exhaust gasket material, and have made a nice template for cutting out the gasket. I also chased the threads with a 6mm X 100 tap, and got all new bolts, so I'm reasonably confident that the exhaust leak problem will be solved.
Luckily, I have some good hot rod shops in the area, and was able to find the right gasket material fairly easily.
Thanks again for your help.
Posted on: 2006/5/16 0:06
