« 1 2 3 (4)
Re: 79 210 engine swap possibilities
Not too shy to talk
From Greeley, CO
Right on. Good luck, and make sure to document things really well for other to see.
Posted on: 2006/5/18 11:22
1979 210 Wagon. Project in the planning.
From UK
I guess the Skyline could be had with AWD. Similar to the S13-S15, right?
R32 Skyline suspension is similar to s14 and I believe R33 is like S14 but the difficulty in using a skyline system is it's designed for the RB 6 cyclinder and one driveshaft actually passes through the oil pan I think. Changing to a 4 cylinder would present some engineering issues... not impossible but difficult. Using the 6 cylinder engine in a B310 would be difficult to say the least, particularly as you'd have no choice as to the engine position as it would be dictated by the front axle location.
It would probably be easier to build a system around GTiR running gear but having had a GTiR for a little while i wouldn't want to...fast but they don't handle well. Too much understeer and to unpredictable through twisty roads. It would be a great deal easier to engineer GTiR stuff into a B11 than a B310.
As for your gas tank. I had an M10 Nissan Prairie (Stanza wagon in the US) which I put a CA18ET into and retained the stock tank and converted to EFI. I used a low pressure electric pump to move fuel from the tank to a small surg tank I made which was mounted under the floor. A high pressure EFI pump was fed from this and the fuel from the fuel rail returned to it. Think of the system as two circuits. the low pressure side circulates fuel from the main tank to the surge tank and back again and the high pressure, from the surge tank to the engine and back to to surge tank. With flat underfloor tanks you are likely to get fuel stavation when cornering so a surge tank is a good idea. I made mane from a piece of flat plate, the top of a 4" disposible welding gas cylinder and some carburettor pipe unions. I probably still have pictures of it somewhere.
Honestly, a CA18DET into a B310 is a pretty easy swap so you should have no real problems if you go that route.
Posted on: 2006/5/18 11:23
Not too shy to talk
From Greeley, CO
That's awesome. I think I saw you had postes some info about that regarding a supercharged 1200. I found a surge tank on Ebay for $48 USD that holds almost .5 gallon. Now that I'm starting to understand it, it's really perfect. For some reason I thought it would hold just a few ounces and run out quickly. Oh well, I'm learning. Any pics you can throw up would be really appreciated. I learn visually very quickly. Thanks for the input.
Posted on: 2006/5/18 12:05
From UK
Here's a diagram of the surge tank system. I'll try to find the pics of the surge tank I made. They're are prints so i'll have to scan them.
-Ed
Posted on: 2006/5/18 12:25
Not too shy to talk
From Greeley, CO
Found another AWD option: Nissan Bluebird
AWD SR20DET. Don't know anything about the importer, but his prices look good.
Thanks for the diagram on the fuel system. Looks pretty straightforward. Gives me a bit more confidence in going forward. Adding parts to my list right now.
Posted on: 2006/5/18 12:34
From UK
The Bluebird is similar in many ways to the GTiR in priciple with a transverse design. There's also AWD B12 and N13 Pulsar/Sentra/Sunny models and M10 Prairie/Stanza wagons. Again, both are transverse engines and use either SOHC CA's or GA series engines.
-Ed
Posted on: 2006/5/18 14:10
« 1 2 3 (4)
