#1 suspension/brake differences between A12/A14/A15 powered B310's?
Mawler1 Posted on: 2006/5/19 11:53
hi guys I just wanted to know if there is an difference between the brakes/suspension on A12/A14/15 powered B310's/Sunny's
#2 Re: suspension/brake differences between A12/A14/A15 powered B310's?
Dodgeman Posted on: 2006/5/19 12:10
My Australian B310/ Sunny workshop manual describes only one type of front brake assembly for all models, & the front suspension uses different front springs for air conditioned models, but everything else seems to be the same.
The aircon springs are 1.7 lbs/ inch stiffer in their compression value.
#3 Re: suspension/brake differences between A12/A14/A15 powered B310's?
Mawler1 Posted on: 2006/5/19 12:26
I do have A/C on "The Yellow Peril" but the springs are quite rusty!
and even though my (currently) only sunny it is an A12: the brakes are
deadly good... when I got it I was thinking "she goes well this is fun" -it was onlt when I had a pragmatic moment and looked under the car I had a "Damn there is more rust in this thing than the TITANIC" moment that I realized "time to park it"
with the advent of the "Silver Sunny" the plan is A15 and possibly extractors and a delorto/webber or two...
dunno know about the webbers/dellorto(s) considering it is a farm hack/paddock bomb...
yes it is a farm hack but I am getting sick of A12's (with the newest Sunny I have SIX - 3 run!
#4 Re: suspension/brake differences between A12/A14/A15 powered B310's?
ddgonzal Posted on: 2006/5/20 8:16
Rusty springs shouldn't hurt anything, unless the front of the car is drooping or something.
Yes, although they look very similar. My 1980 factory service manual lists two:
- Caliper "AN18" used on Canada A12A models
pad size: 42 x 56.8 mm
rotor diameter: 220mm
- Caliper "AN20" used on USA models
pad size: 41.2 x 61.4 mm
rotor diameter: 245mm
Note that A14 B210s had the biggest brakes.
USA B210 (1976-1978) used:
pad size: 41.2 x 63.4 mm
Compare to B110 disc brakes:
Model ANNET 12/14A
pad size: 42.5 x 53.1 mm
rotor diameter: 212.5mm
reference: Suspension & Brakes Overview in Tech Section.
#5 Re: suspension/brake differences between A12/A14/A15 powered B310's?
b310gx Posted on: 2006/5/21 0:17
my b310 panel van had larger brake pads than the sedans & coupes,they were the same size as 1600 (p510) pads,so no problems getting replacements.
