TRX rims
Quite a regular
From sydney
recently a mate just bought a pair of simmons and i was wondering if i could use his 15 or 16 inch trx rims on my stock 12 datto wat modifications would need to be done for this to be able to work
cheers
Posted on: 2006/5/31 14:45
Re: TRX rims
From SE Melbourne
As long as he gives you the wheel nuts that go with them, you will be able to fit them...and they should be 15" I think....hmmm.
You will need the special TRX wheel nuts though.
Posted on: 2006/6/1 1:37
Mildman, Datsunless
Re: TRX rims
From brisbane, qld
wont fit onto stock drum brake front end, and wont fit onto 120y disk brake front end.
you need sunny or stanza front end to make it work.
Posted on: 2006/6/1 3:15
Re: TRX rims
Quite a regular
yeah, there a 15... but they dont fit onto a sunny front stock, not on mine anyway stanza struts would be the go
Posted on: 2006/6/1 9:53
Re: TRX rims
From brisbane, qld
stanza struts are exactly the same as sunny struts except stanza's have girlocks. you must have 120y struts. my ute has sunny struts and takes trx rims with 195/50's with about 3mm clearance, no rubbing on struts.
Posted on: 2006/6/1 10:07
Re: TRX rims
Quite a regular
From sydney
so which is it?
stanza, sunny, or 120y
and where can i get this stuff if i live around the easter beaches in sydney
Posted on: 2006/6/1 11:03
Re: TRX rims
From south coast nsw
i have drum front end and they fit?you just need spacers.
Posted on: 2006/6/1 11:27
Re: TRX rims
From brisbane, qld
Spacers are dodgey not to mention illegal. They increase the risk of snapping wheel studs. You could get away with it though,but changing to the sunny/stanza disk set up isn't that hard nor expensive(I was quoted $120 for the parts needed)plus the car will stop better!
Posted on: 2006/6/1 12:44
