Re: A series injection and turbo setup
From Perth Western Australia
Hey been having a good look at the gear on e-bay.
Just getting together in my head whats left to complete on it - as i'm but a novice mechanic I need to plan b4 jumping into injection.
So the injector bosses need welding on to the manifold &the flanges need finishing and welding to the runners then the runners to the plenum and the exhaust manifold needs to be made up (after sorting out the inlet side obviously)
You mention that its set up for ca18det injectors does it come with these?
and what other sensors are needed for the ecu, you mention the oxygen sensor but do you have all the others required to run it?
thanks
Posted on: 2006/6/7 4:43
Subject Poster Date
     A series injection and turbo setup LAGWAGON 2006/6/4 3:25
       Re: A series injection and turbo setup 120fly 2006/6/4 5:22
         Re: A series injection and turbo setup LAGWAGON 2006/6/4 6:47
           Re: A series injection and turbo setup LAGWAGON 2006/6/4 12:55
             Re: A series injection and turbo setup phunkdoktaspok 2006/6/4 13:23
             Re: A series injection and turbo setup mopar 2006/6/4 14:02
               Re: A series injection and turbo setup LAGWAGON 2006/6/5 12:03
                 Re: A series injection and turbo setup mikecz 2006/6/6 6:21
                   Re: A series injection and turbo setup BVC_Bullet 2006/6/7 0:20
                     Re: A series injection and turbo setup LAGWAGON 2006/6/7 1:05
                       Re: A series injection and turbo setup kue1000 2006/6/7 4:43
                         Re: A series injection and turbo setup LAGWAGON 2006/6/7 8:29
