« 1 (2)
#11 Re: What other upgrades needed when fitting a15, brakes etc.
Dodgeman Posted on: 2006/6/7 5:42
The disc brakes on the B310/ Sunny/ 210 were designed to handle a car of 1985 Lb [900 Kg Sunny Sport Wagon] but if used in a 1200 coupe that weighs 1520 Lb [691 Kg] then brake performance is improved substantially for that reason alone. The maximim legal speed here is usually 110Kph [68mph] so this brake setup should prove more than adequate in the majority of cases in an A series powered car. Fitting a Lancer power booster will further enhance brake performance if this is felt to be necessary.
Other cars with more powerfull engines & higher performance can still use the B310 strut, but with better brakes as these are not hard to adapt. Even the bigger, local Commodore caliper just bolts right on.
#12 Re: What other upgrades needed when fitting a15, brakes etc.
clammy Posted on: 2006/6/7 5:50
get the brakes off a pintara or trx or whatever theyre called....
i got 4 of em on my ute and it pulls up a treat....
#13 Re: What other upgrades needed when fitting a15, brakes etc.
killer1200 Posted on: 2006/6/7 12:16
In SA you can put in a A14 without changing brakes but it is a good idea.
It all really comes down to what you want to spend.
#14 Re: What other upgrades needed when fitting a15, brakes etc.
greendog Posted on: 2006/6/7 12:31
the residual pressure check valve is it located at the bottom of the resovior? and you just remove it hey?
#15 Re: What other upgrades needed when fitting a15, brakes etc.
Mildman Posted on: 2006/6/7 14:07
To be a litte more specific, but still being too lazy to link to the threads, I remember talk about S13 calipers and rotors on a 120Y strut, which is some pretty serious braking power - well above that offered by a set of girlocks on the Stanza strut - meaning maybe it's possible to get a whole lot of braking power out of a 120Y strut....which would mean top brakes and lower unsprung weight!
More think out aloud than actually presenting a well researched point....
« 1 (2)
