disc brakes
From Adelaide, SA the drift state
hey guys going on sat to pick up all the #### i need to get a shopping list
wat do i need to fit disc brakes to a 1200 ute
Posted on: 2006/6/7 10:19
Re: disc brakes
From Bendigo, Victoria, Australia.
this mite help. although the article is for a sedan, should have relevance to your ute.
Posted on: 2006/6/7 10:45
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
Re: disc brakes
so all i need is replacement struts, master cylinder and front brake lines
whoever has done this plz help
Posted on: 2006/6/7 12:11
Re: disc brakes
From Adelaide, South Australia
What brakes do you plan on using ?(for is that what your asking).
Also if you've got the newer style master cylinder you dont need to change it what year is your car ?
Posted on: 2006/6/7 12:22
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
Re: disc brakes
From Adelaide, Australia
Thats not true, my partners car ran around for over six months on the 70's single master with the stanza upgrade, was a little firm on the pedal thats all.
Posted on: 2006/6/7 13:40
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: disc brakes
He hasnt even said what brakes he plans on using yet.
Posted on: 2006/6/7 15:14
Albert Einstein
Re: disc brakes
hey guys its a 1982 ute
i dont wat discs im using wateva i can pick up at the wreckers anyone tell me were i can get a good set in SA adelaide and is a it a straight forward change
Posted on: 2006/6/8 11:16
Re: disc brakes
What are you going to be doing with the car, what engine does it have etc. Have a read through the tech section lots of information there for you.
Posted on: 2006/6/8 12:11
IPRA Build
Re: disc brakes
all i need to kno is wat should i put on my shopping list i am going to use stanza components. it has standard engine but a ca turbs is coming after i fix rust and brakes and blah blah blah
Posted on: 2006/6/8 14:42
Re: disc brakes
From Bris-Vegas
You need a Silvia / 180sx / 200sx front brake conversion my friend.
Silvia front discs, 120Y struts, longer studs (R31 Skyline will do from memory) & a caliper adaptor plate & you are set.
I'm not sure who you'd talk to about the adaptor plate in your neck of the woods.... Maddat maybe?
Posted on: 2006/6/8 23:41
CA18DET '74 1200 ute project
