#1 which master cylinder?
blofly Posted on: 2006/6/12 15:07
I got this information off of the PBR website for replacement brake parts.
I need a master cylinder that will work with a set of 120Y front disc brakes and 1200 rear drums. The car is a 1973 auto 1200 sedan but I can't figure out which master cylinder to order, here is the list.
ACTUATION Brake M/Cyl - Suit: 03/1974 - 12/1976 17.46 mm DISC/DRUM W/O MVAC JB1196
ACTUATION Brake M/Cyl - Suit: 01/1975 - 12/1977 19.05 mm DISC/DRUM WITH MVAC JB1181
ACTUATION Brake M/Cyl - Suit: 01/1977 - 03/1979 19.05 mm COUPE SEDAN DISC/DRUM PBR ORG P7217
ACTUATION Brake M/Cyl - Suit: 01/1978 - 03/1979 19.05 mm ALL BODY TYPES DISC/DRUM JB1172#(NLA)
ACTUATION Kit-B M/Cyl (Min) - Suit: 03/1974 - 12/1976 17.46 mm DISC/DRUM W/O MVAC K7605X#(NLA)
ACTUATION Kit-B M/Cyl (Min) - Suit: 03/1974 - 12/1976 17.46 mm DISC/DRUM W/O MVAC K7859X
ACTUATION Kit-B M/Cyl (Min) - Suit: 01/1975 - 12/1977 19.05 mm DISC/DRUM WITH MVAC K7606X
ACTUATION Kit-B M/Cyl (Min) - Suit: 01/1975 - 12/1977 19.05 mm DISC/DRUM WITH MVAC K7860X
ACTUATION Kit-B M/Cyl (Min) - Suit: 01/1977 - 03/1979 19.05 mm COUPE SEDAN DISC/DRUM PBR ORG K7627X#(NLA)
ACTUATION Kit-B M/Cyl (Min) - Suit: 01/1978 - 03/1979 19.05 mm ALL BODY TYPES DISC/DRUM K7606X
ACTUATION Kit-B M/Cyl (Min) - Suit: 01/1978 - 03/1979 19.05 mm ALL BODY TYPES DISC/DRUM K7860X
ACTUATION Kit-B M/Cyl (Alt) - Suit: 03/1974 - 12/1976 17.46 mm DISC/DRUM W/O MVAC K7638X
#2 Re: which master cylinder?
dattoman_1000 Posted on: 2006/6/12 15:22
JB1196 is for disc front with no booster 11/16"
The pushrod is seperate to the master and stays on the pedal when the master is removed
JB1181 and JB1172 are the same thing 3/4"
They suit boosted system
This would be your minimum master to use
I'd probably step up to the Sunny master JB1289 which is 13/16"
The P7217 is PBR ADR stle unit with the big recatangular bottle.
#3 Re: which master cylinder?
short-coupe Posted on: 2006/6/15 11:57
is there much difference in piston bore size from the 120y to the 1200 coupe calipers, i would have thought the 11/16 would suit? do u need a larger m cyl for disc / disc? i'm running the 13/16, but with twin sumi's and R31 rears, and i only have about 10mm of movement before the pedal is hard? i'm running no booster
#4 Re: which master cylinder?
killer1200 Posted on: 2006/6/15 15:39
You can run a 4 pot front with a 2 pot rear with a 7/8 tandem master cylinder without a booster so you should be fine.
#5 Re: which master cylinder?
dattoman_1000 Posted on: 2006/6/15 15:42
Both run same 48mm pistons
#6 Re: which master cylinder?
blofly Posted on: 2006/6/15 15:51
would the JB1289 fit into the 1200? and would the 1200 brake lines bolt up to it ok? would there be any modifications needed to fit the unit?
#7 Re: which master cylinder?
B210sleeper Posted on: 2006/6/15 18:42
the largest sunny MC works fine with wilwood 4 pots and the rear drums.
i think all the hardlines are the same.
#8 Re: which master cylinder?
dattoman_1000 Posted on: 2006/6/16 12:22
Yes
Yes
No
#9 Re: which master cylinder?
Boostin Posted on: 2006/6/17 14:56
i agree with killer1200, talk to craig at mad dat, he has the know how...
#10 Re: which master cylinder?
