« 1 (2) 3 »
Re: Crystal Headlights
From Brisbane Australia
I put Hella inserts in my 85 ute way back when I was a young stud .
I used 90/130 watt inserts and I also had a set of lucas "mean mother" spotlights and when I did my first intestate trip they turned night into day and the old prick in the 240 who would not dip his lights is probably still seeing stars and that was twenty years ago.
I definately recommend going H4 and the correct bulb to keep it all legal are 55/60 watt .
cheers Ade
Posted on: 2006/6/17 8:47
Is there a tech section on the Hyandai lights as when I will be back on the road I will need some good lighting, could be a fair bit of night commuting.
any info would be greatly appreciated
Posted on: 2006/6/17 11:10
From Wamboin near ACT(canberra)
i am currently looking at upgrading the lights in my 1200 ute. wat do ppl recommend. reading throuh this post is a bit confusing. anybody have a straight forward answe. im not really looking at a fiddling round job, just pretty much a straight swap around
Posted on: 2006/6/17 11:29
COUP1200 wrote:
i used h4 hella inserts i recomend them
Dodgeman wrote:
Hella inserts with relays & a carefully adjusted regulator [where applicable]
Run the relays as all of the current for stock lights passes through the switch [at least on pre '74's it does] & uprated bulbs will make this pretty hot pretty quick.
I ran the standard 55/60's in my '73 model 1200 ute & they were great.
Posted on: 2006/6/17 11:50
Love your Datsun.
Treat it well.
From Brisbane, Narangba
I agree, relays make a huge difference. I measured mine at a measley 9.5volts before the relay. Now they get a min of 12v from the battery and 14.2 when the alternator is cranking. Soooo much better.
Also my 71 stocka actually has decent lights where as my 73 really needed the relay. Probably because the wiring was molested by the previous owner.
Posted on: 2006/6/17 12:03
From Sydney
hey ben you got anymore of those headlights with globes? i am keen for a new set that are actually bright
yeah mate i can get some more let me know
Posted on: 2006/6/17 12:12
From sydney,Australia
as soon as possible if you cuold that would be great thanks mate. just let me know when we get em
Posted on: 2006/6/18 4:18
From Brisbane
i can buy brand new glass one's for $70 a pair, or plastic ones for $66 a pair. bulbs standard H4 are $10ea. blue tint are $25 ea.
Posted on: 2006/6/18 9:18
From Sydney
my mates got a couple of pairs $60 brand new hella's
hella globes $5 each
sydney only
Posted on: 2006/6/19 3:16
From Bunbury Western Australia
so to run a relay for the lighting system would I need to run one seperate relay for the low beam circuit and another seperate relay for the highbeam circuit? any other tips would be great
Posted on: 2006/6/19 14:47
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
« 1 (2) 3 »
