what diff come in the C20 van's?
From Bunbury Western Australia
I have found a C20 van for sale for $200 and am hoping it has a H165 if so can someone confirm so I can celebrate?
Posted on: 2006/6/21 13:46
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
Re: what diff come in the C20 van's?
have fitted one before to a coupe, it was a little wide. even with frony wheel drive offset rim the tyre just hung out the guards.
Posted on: 2006/6/21 13:58
From Townsville, Qld
I believe they come equiped with the H190 with the most common ratio being like a 3.2 or something like that
Posted on: 2006/6/21 15:58
From Sydney , NSW
I have a C20 in my coupe and they are a tad wide. You may have to hunt for correct offset wheels/ or flares - but it is not an impossible fix. Spring mounts will have to be relocated also Good news is it will be an H165 and probably a 4.875 : 1
Good luck!
Cheers
Posted on: 2006/6/21 22:52
Are you looking for a diff,[differential] or a rear axle assembly. [whole rear end]?
I am of the belief that the smaller Vanette's with A series engines has H165's while the larger Urvan sized vehicles had H190's.
Can someone confirm or refute?
Posted on: 2006/6/21 23:16
Love your Datsun.
Treat it well.
I was hoping to do a straight swap over with the whole diff assembly, but I will have to find the right wheels first, what offset would I need to fit the wheels to the diff?
Posted on: 2006/6/22 2:34
From Perth Austarlia
i think the diff i have lying around came out of a C20. I'm pretty sure its an h165 as it has 8 nuts/bolts?? and it seems way too wide. you may also need to move the shock mounts?????
Posted on: 2006/6/22 4:02
Is a c20 Vanette a "c120" Vanette? cos that's where I'm getting my info from
Posted on: 2006/6/22 4:40
The van is listed on www.quokka.com.au under a datsun search
DATSUN C20 van, eng excel cond, front panel damaged, suit repair or parts $200 ono. Quinns Rcks. 0421-301-789
Posted on: 2006/6/22 5:40
From Sydney , NSW
Dodgeman you are right as usual ......
C20 Vanette - A series - H165 (4.875:1)
Vanette - bigger brother - H190 (alloy 4.6:1)
Thats what I have got anyway ....
Point to note - H190 stated above has 23 spline axles same as H165.
Cheers
Posted on: 2006/6/22 6:55
