Re: need advice on engines
From south australia
a rebuild kit for an a series is around $400 you could get a second hand a14/15 for around the same price
maby you should give the origonal motor a compresion test to see if all cylinders are even.
Did you get all the water out of your engine when you replaced the head gasket
Posted on: 2006/6/22 11:49
Subject Poster Date
     need advice on engines rusty1200 2006/6/22 11:38
       Re: need advice on engines Turboute 2006/6/22 11:44
       Re: need advice on engines blofly 2006/6/22 11:47
       Re: need advice on engines rb20 2006/6/22 11:49
         Re: need advice on engines Homer 2006/6/22 11:55
           Re: need advice on engines Datsfullysik 2006/6/22 13:56
             Re: need advice on engines rusty1200 2006/6/22 21:51
               Re: need advice on engines Mildman 2006/6/23 0:14
                 Re: need advice on engines Mat_1200ute 2006/6/23 12:09
                   Re: need advice on engines rusty1200 2006/6/23 13:41
                     Re: need advice on engines campo 2006/6/24 1:02
       Re: need advice on engines datto_lowrider93 2006/6/24 4:04
