Front stiffened springs about 30 - 40mm short
From London, UK
Hi
Do you know if there is any company that does shorter/stiffened front springs for 1973 datsun 1200 Saloon or does anyone has a pair they want to sell? I can't get them here and may have to get them made to order.
Posted on: 2006/6/25 23:45
Re: Front stiffened springs about 30 - 40mm short
From Invercargill, New Zealand
Check out the King Springs catalogue
Look under Nissan
Posted on: 2006/6/26 1:22
From Bunbury Western Australia
King Springs Part No's KDFL-57 (front) & DAT-502R (rear) to lower your vehicle approximately 35mm from factory std height. Rear leafs are different between sedan and coupe.
These coils are designed with an increase in spring rate of approximately 25%.
front springs are $155 plus GST rear are $300 plus GST
Posted on: 2006/6/26 4:04
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From London, UK
Hi Blofly & Teretonga - Many thanks for your help. I guess now it will have to be a costing exercise and get them from OZ or get them manufactured here by special order
Posted on: 2006/6/27 19:28
From Brisbane, Australia
What about 240Z rear springs?
Might be easier to source locally.
Posted on: 2006/6/28 0:10
I think with the z springs you would want stock ones. Aftermarket kings or something would be really stiff.
Might be worth asking on a z forum, someone probably has some sitting around soemewhere
Posted on: 2006/6/28 1:31
From Burbank, CA
does pedders make them? i got some for my 120Y ( sunny B310 whatever )
Posted on: 2006/6/28 2:29
|||\ 81 KPB310 /|||
pedders only make standard height replacement springs unfortunately
Posted on: 2006/6/28 8:25
From Burbank, CA
not for the 1200? they make lowering springs for the 120Y
Posted on: 2006/6/29 23:22
|||\ 81 KPB310 /|||
From Townsville
I have just had Pedders lowered springs fitted into the front of my B120 ute, they are lowering the front by at least 20mm, being that i can only assume that they are 120y because they have no listing for the utes..... i knows it's not 30 - 40 mm but still Pedders can supply.
Cheers, Geoff
Posted on: 2006/6/30 9:24
