CA18DET Turbo/Supercharge Set up HELP!!
From Brisbane
Hi All,
I have just bought a coupe with a CA18DET setup also running a Toyota (i think) Supercharger. It seems to work by all intake air being drawn through the turbo - Running thru Air to Air front mount then air flow meter and throttle body then to front of plenum where it goes to supercharger or intake. It has a acuator fitted to the start of plenum which is not connected. If air goes to supercharger it then goes thru water to air intercoller and enters rear of plenum.
Can any one tell me if this type of setup works well?
Also when and how does the front plenum acuator work? (its not connected)
any advise or feedback is great.
I will post pic to help explain if someone can tell me how.
Cheers
Jason
Posted on: 2006/6/21 15:55
Re: CA18DET Turbo/Supercharge Set up HELP!!
From Newcastle
hey camp sounds like uv got a bit of a handful their. . .i duno wetha ill b able 2 help but send me sum photos and ill take a look.. . Boostin10flat@hotmail.com
Posted on: 2006/6/21 16:20
From Inner west nsw CAMDEN
just to help u out a bit the charger takes over from 0 to 3 grand so little to none turbo lag get in the way of power hope i helped
Posted on: 2006/6/22 13:07
FAT 120Y SR20de-NOS
What speed are you doing at M kmh???
Bet my bonnet scoop is bigger than YOURS!
Do wheelie bars suit a street car?
From South East QLD
is the Car still running the wolf ecu ?
Iam running a twincharge set up ,,
Posted on: 2006/6/22 13:38
From Ipswich
Hey there
This sounds like my dads car. We built this car 4 or more years ago. I made all the set up myself and would love 2 see the car again. If u need a hand give me a call on 0421316757.
Posted on: 2006/6/26 11:20
From Brisbane
not being rude, but turf the supercharger, and all the extra plumbing, and just run the turbo.
Posted on: 2006/6/28 9:28
dont turf the charger that would make a really good quick streeter all together
Posted on: 2006/6/28 12:15
FAT 120Y SR20de-NOS
From Brisbane
the toyota charges run out of puff to early,
Posted on: 2006/6/28 15:38
From south australia
the turbo will pick up where the supercharger left off
Posted on: 2006/6/28 15:40
