« 1 2 (3)
Re: engine keeps cutting out
From Sydney Australia
Maybe I checked mine and it was ok
Posted on: 2006/3/24 6:15
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
From Stray-ya
731200 wrote:
Most of the time around 9pound but sees 15pound a few times a week or when im testing
and I thought you were running a relativley mild setup.
Posted on: 2006/3/24 8:38
Quite a regular
From Brunswick, Melbourne Australia
I had the same prob a while back with the Hitachi carb, it seems sthat if the primary jet is blocked the motor will only work at high revs. One thing that blocks the primary jet is the octagonal shaped "anti diesel" solonoid that pokes out on the engines right (from the drivers point ov view). What this thing does is restrict fuel at shutdown. Say it woz broken then it would close the the primary all the time, causing it to only run at high revs. The way to test it is to see if it makes a "click" noise when the ignition is turned on. If the solonoide does'nt go "click" with ignition, there's your prob. I got one from a wrecker for $20 and it fixed everything.
Posted on: 2006/7/2 1:11
« 1 2 (3)
