How long does fuel last?
From brisbane
I took my car out for a run yesterday afternoon after leaving it in the garage for the last couple of weeks and noticed that at high revs and boost it was pinging. I always use BP Ultimate and have never had this issue before. The current tank of fuel has been in there for 5 to 6 weeks. Can fuel go 'off' that quickly?
Matty
Posted on: 2006/7/3 15:34
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Re: How long does fuel last?
From Townsville, Qld
Like most things now I'd say "Yes, yes it can". I just moved an old 2 stroke mower of mine and the tank leaked and you'd think it was water based red paint or something that came out
Posted on: 2006/7/3 16:00
From Adelaide, South Australia
Yeah it will get water in it and thats what will make it go bad.
Posted on: 2006/7/3 23:16
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From brisbane
I was thinking about the water situation after I posted. Because the tank has been less than half full for quite a long time and the weather has been cold that would allow condensation to build up inside the tank.
Thanks for the responses guys.
Regards Matty
Posted on: 2006/7/4 1:37
Gasoline can last years. I've started many cars using fuel in the tank that was at least 5 years old.
water in the tank doesn't cause pinging...
Posted on: 2006/7/4 7:29
From Brisbane, Australia
having been involved in racing for years, I've heard alot of stories like this of cars pinging after being left to sit for a period of time with optimax in the tank. fresh fuel fixes the problem.
common wisdom is that optimax (and other 98RON fuels) have a relatively short shelf life of around 3 weeks before the RON drops significantly.
the official word from shell is somewhat non-commital. They say the fuel will be stable if stored up to one year, as long as the storage conditions are "adequate" - ie the containers are full to minimise exposure to air, tightly capped, out of direct sunlight, and under 27
Posted on: 2006/7/4 9:08
From brisbane
Thanks Harry.
I generally fill the tank more regularly as I usually drive the car more. I'll fill it up tonight and see if that fixes the issue.
Posted on: 2006/7/5 1:55
fuel lasts for months get it checked i dont think it would be your fuel
Posted on: 2006/7/6 17:12
From Bendigo, Victoria, Australia.
have you looked at anything electrical? i think it might lie elsewhere too.
but buy a tank of fuel first.
Posted on: 2006/7/6 17:40
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
Quite a regular
From Atlanta,Ga U.S.A.
Ive always heard that gas goes bad after sitting for about a month. I dont think its water that makes it go bad(although if theres water in it thats not good). What happens is the unstable gasoline molecule breaks down and degrades over time. It can still run in an engine but ive read that it breaks down into a chemical that can ruin fuel lines and rubber seals.
Posted on: 2006/7/7 12:56
