Re: rear brake drums.
From Flinders View, QLD
You could fit wider drums but the centre of the drum wont fit over the axle hub which would be very bad. If you dont want to change the offset of your rims (which would be the easiest) you could put a spacer between the diff flange and brake setup. Problem with this is it will pull the axles out of the centre the thickness of the spacer hence you will need longer axles. Got any ideas???
Posted on: 2006/7/5 18:06
Subject Poster Date
     rear brake drums. Anonymous 2006/7/5 10:42
       Re: rear brake drums. BUNDY351 2006/7/5 13:28
         Re: rear brake drums. Anonymous 2006/7/5 16:04
           Re: rear brake drums. BUNDY351 2006/7/5 18:06
             Re: rear brake drums. Anonymous 2006/7/6 6:00
               Re: rear brake drums. PIGDOG 2006/7/6 11:08
                 Re: rear brake drums. blofly 2006/7/6 11:44
                   Re: rear brake drums. PIGDOG 2006/7/6 19:04
