Re: having second thoughts
From Lismore, NSW
they will probably be rewarding but trhere are probably cheaper ways of getting more grunt out of your A-15
What are the cheaper ways of getting more grunt ?
Posted on: 2006/7/10 13:30
webers are fidily complicated pieces of machinery but when tuned nicely will offer a great deal of improvement in performance and when combined with a nice cam and headers they often work together to give you an even greater power output.look what im trying to say is if this person tunes them right they should be well worth your money.
Posted on: 2006/7/10 13:49
From Australia, NSW near Tamworth
If they are set up right they will be good.
I spoke to a guy who broughta 2litre mustang back celica brand new in 1977. He had the dealer put twin webbers on then. He has barely touched them since,
that's good enough for me.
Posted on: 2006/7/10 15:39
From Florida, USA
Had a set (pair) of 40DHLA Del Orreto carbs on an A12. I think that these are very similar to Webers. Raced this car for 4 years, let it sit for 3 and put it back on the track and it still ran beautifully. The only adjustments that were required, re-jetting when going from high altitude to near sea level. Oh, I think I checked the float level one time also.
While getting the venturi diameter and overall sizing right is important, if you have too small a carb it will just limit your top end, make sure that you get the air corrector and main jet right for proper off idle and mid range performance. You may have to play with it a bit. This is why guys who race them have a box full of jets.
Posted on: 2006/7/10 17:17
From Wamboin near ACT(canberra)
the place that is doing all the work, is HIGHLY recommended by most rally guys. i have heard very impressive comments about this place and when i went in 2 talk 2 them he was very helpful. I suppose its 2 late 2 back out now anyway, there going 2 be tuned on monday, and set up. cant wait
Posted on: 2006/7/10 17:26
The simple fact is that these things need to be correctly tuned & you need quality linkages that won't slip. Once everything is as it should be, you will not need to touch them again unless you change something major. [like moving from Death Valley to Nepal] Jets don't wear or go out of adjustment & as long as the carbs stay in synch, you will get many years of happy motoring.
Use them untuned, or with second rate components, & you may well rue the day you ever saw them.
Spend whatever it takes to get them right, & we'll hear you singing their praises from miles away.
Posted on: 2006/7/10 18:55
Love your Datsun.
Treat it well.
I have webbers on my a12 and i love them. Nice response, and sound very tuff. You will love the sound difference it makes on your car for sure.
Posted on: 2006/7/10 20:25
another thing is, i am still running the 4 speed gearbox, this will have 2 be upgraded asap, with fuel and all. I bought the whole set up off kegs, and its all there which makes life alot easier. i am excited, and a tad nervous 2 get it all hooked up. i am putting an electric fuel pump on and also thinking of electric ignition. fingers crossed
Posted on: 2006/7/11 13:36
when you start your car you will hear your webers you will smell your webers thats when you know youve done the right thing and i guarentee you will enjoy the sound and the smell for the rest of your life
Posted on: 2006/7/11 14:09
definitley go the electronic ignition, the stronger spark makes a huge difference with performance.
Posted on: 2006/7/11 16:17
« 1 (2) 3 4 »
