I couldn't login for the past week.
From Sydney, Australia
I used the forgot password options, and it wasn't helping. It was caused by Symantec Internet Security. I disabled the Internet Security, and it all works now. How embarassing..especially as I work for Symantec.
Posted on: 2006/7/22 6:13
Re: I couldn't login for the past week.
From Gold Coast
At least your back now,
Hows the build going?
Posted on: 2006/7/22 6:27
Going pretty well. Got a bad dose of the flu 2 days ago, and still recovering. Damn holidays..always end up getting sick, after the stress levels drop.
Could have got the car running today if I hadn't got sick. It'll have to wait until end of next week. I've redone the brake lines and master cylinder including using a bias valve on the rear line. I resprayed the front panel, after chopping out the radiator support panel and remaking the support panel for frontal rigidity. I also remade the lower radiator crossover pipe, modified the LA/LB Lancer Master cylinder bracket to suit the 1200. So the brakes should be damn solid now. I installed a 23mm front swaybar (custom from allsprings at liverpool for only au$210 including urethane bushings). I told them I want it the same as a 1200 one, with 1 inch more bar forward to clear the CA18 sump. I supplied them with a 1200 standard one as a template. It went in fine.
So a lot got done this week, but not quite enough to get the car running again.
Posted on: 2006/7/22 6:42
From Gold Coast
One more week is not to long to wait.
Posted on: 2006/7/22 7:08
From Melbourne AUS
i had the same problem! glad i read your post.. who knows how long i could have been shut out for!
Posted on: 2006/7/23 2:29
1973 B110 A12
From Mudgee NSW Australia
Hey Chris Ive had simaller problems for the last 12 months.
I can log on to 1200.com fine but when I go to answer or post it just ####s itself. I now disable nortons internet security to make any posts and all is good although I still having some wierd things happening with email and pm's
Cheers Andrew
PS: you coming to the track day on the 11th??
Posted on: 2006/7/23 11:31
If In doubt run more BOOST
Quite a regular
From Perth, WA
nortan is evil
get avg
Posted on: 2006/7/23 11:46
ah, Norton ... it has been causing problems here for years: The great 1200.com lockout.
Posted on: 2006/7/24 1:17
From Brisbane
I found that Zonealarm was also bad with this site had lots of problems over the years with it.
Posted on: 2006/7/24 3:02
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
