Re: Flooding carbs
Not too shy to talk
From Carson City,NV USA
Hi, Dave your float valves could be hung open, or you might of had some sediment in the bottom of your float bowls and it is now plugging some of your jets.I would remove the float covers and check the float movement. Then remove the jets one at a time and blow them out with carb cleaner. That should help your problem or give you a good starting point as to whats not wrong with your carbs. Good luck Larry.
Posted on: 2006/7/23 23:42
Subject Poster Date
     Flooding carbs fixed. Anyone for a milkshake?! datrat_dave 2006/7/23 10:23
       Re: Flooding carbs blofly 2006/7/23 10:42
       Re: Flooding carbs nismo 2006/7/23 11:12
         Re: Flooding carbs datrat_dave 2006/7/23 14:08
           Re: Flooding carbs kegs 2006/7/23 14:13
           Re: Flooding carbs datracer 2006/7/23 23:42
             Re: Flooding carbs ddgonzal 2006/7/24 1:07
       Re: Flooding carbs bobs1200 2006/7/24 2:42
         Re: Flooding carbs datrat_dave 2006/7/24 12:52
           Re: Flooding carbs WhiteSedan 2006/7/24 12:55
             Re: Flooding carbs fixed. Anyone for a milkshake?! datrat_dave 2006/7/25 9:08
               Re: Flooding carbs fixed. Anyone for a milkshake?! Niscoupe 2006/7/25 9:48
                 Re: Flooding carbs fixed. Anyone for a milkshake?! DemonFreeman 2006/7/25 12:04
                   Re: Flooding carbs fixed. Anyone for a milkshake?! chris1200t 2006/7/25 13:22
                 Re: Flooding carbs fixed. Anyone for a milkshake?! datrat_dave 2006/7/25 13:31
                   Re: Flooding carbs fixed. Anyone for a milkshake?! R-fastmotorsport 2006/7/25 22:50
                     Re: Flooding carbs fixed. Anyone for a milkshake?! datrat_dave 2006/7/28 8:52
                       Re: Flooding carbs fixed. Anyone for a milkshake?! datrat_dave 2006/7/29 8:00
                         Re: Flooding carbs fixed. Anyone for a milkshake?! converted 2006/7/29 11:09
                           Re: Flooding carbs fixed. Anyone for a milkshake?! blofly 2006/7/29 13:44
                             Re: Flooding carbs fixed. Anyone for a milkshake?! ddgonzal 2006/7/29 18:38
                               Re: Flooding carbs fixed. Anyone for a milkshake?! datrat_dave 2006/7/31 11:33
                                 Re: Flooding carbs fixed. Anyone for a milkshake?! chris1200t 2006/7/31 13:38
                                   Re: Flooding carbs fixed. Anyone for a milkshake?! ddgonzal 2006/8/1 5:00
                                     Re: Flooding carbs fixed. Anyone for a milkshake?! blofly 2006/8/2 13:02
                                       Re: Flooding carbs fixed. Anyone for a milkshake?! datrat_dave 2006/8/3 10:18
                                         Re: Flooding carbs fixed. Anyone for a milkshake?! R-fastmotorsport 2006/8/3 13:09
       Re: Flooding carbs fixed. Anyone for a milkshake?! chris1200t 2006/7/25 11:27
