(1) 2 3 4 5 »
Spring Rates q's
From Adelaide, Australia
Hey guys, time has come to order some springs for the Front of my LSeries 1200. Car will remain on the road for now but will see the track more than enough to warrant good suspension.
I have 280zx Struts with a 2.5" (65mm ID) coilover setup.
Using Koni inserts (adjustable reds) also will be running Nolathane bushings front and rear.
I also have noltec strut tops and adjustable stanza lca's.
Also using a 19mm 120y sway bar.
Rear will be using the leafs i already have which are about 20% stiffer than stock, I have noltec bushings for rear and haveing some plastic front bushings and alloy shackle bushings made up at the moment. I have Koni reds for the rear also.
What spring rate would you guys suggest for the front? Im thinking around 200lb?
Posted on: 2006/8/1 10:34
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: Spring Rates q's
From Bunbury Western Australia
that sounds like an awesome set up but all I can offer from my tiny brain is that king springs have 25% increase in spring rate over standard springs, if you know what the standard spring rate is then you can work out what the king spring rate is, does that make sense at all?? if not king springs can custom make any spring to suit your needs.
Also Nolathane don't make 120Y swaybar bushes but Noltec do. What do you mean by adjustable lower control ams
Posted on: 2006/8/1 13:33
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
200lb's not that heavy ..... maybe up towards 250 - 275 lb ?? you should also consider the additional weight of the L series and what you should be looking at to cater for it ??
........ c'mon some of the racers out there must have some opinions ??
Posted on: 2006/8/1 13:35
Cheers guys, this is all happening this week, ive got the coilovers all welded on and the tops machined to match my coilovers. Also got brand new vented discs and rebuilt my calipers.
Anyone used Lj castor rods? What bushings have you used?
Blofly, Craig from Maddat makes stanza adj lower control arms, they allow you to adjust the width of the front track, they are high quality, also tig welded for strength.
Posted on: 2006/8/1 13:51
IPRA Build
i went looking for a pic of the lower c/a and checked the maddat site but its being redesigned would it be possible if you could put a pic of yours up on here as i'm interested to see them again ??
cheers
Posted on: 2006/8/1 13:55
This isnt my photo by the way. I'll have some of it all in the car hopefuly after the weekend!
Posted on: 2006/8/1 14:01
IPRA Build
cool, thanks for that. i'm guessing these are the maddat ones ?? look like it from memory. do you have to supply them with change over control arms or do they have their own ?? any idea on $$$$ ?
sorry for all the q's
ed it : any idea on how much adjustments in the thread section ?
Posted on: 2006/8/1 14:04
Yeah they are off Nexcent website who sell his bits, price wise about $300 exchange but you'd have to call him because of postage etc.
They go to about a inch longer than stock stanza lca's, which equates to about 2.5
Posted on: 2006/8/1 14:10
IPRA Build
From Melbourne Vic
boof, you have camber tops!!!!! don't waste your money on these things if you have camber tops. if anything just extend your LCA's and use the adjustment in the tops to get your desired amount. i have made some in the past that are adjustable with a left and right thread so you can adjust them on the car. i have all the tooling if you're interested.
on the spring rate thing, boofhead was right 250 - 275 lb springs are not uncommon on track going road cars.
Posted on: 2006/8/1 14:12
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
So its looking to be from anywhere from 225lb +
Also taking into account the stiffness of the 120y swaybar which is apparently another 45% stiffer over the 1200 bar?
The only reason im going for as much adjustment as possible is the amount of camber i actually loose with the 280zx struts which is a fair bit compared to stanza struts.
Also then i can adjust front track.
Posted on: 2006/8/1 14:16
IPRA Build
(1) 2 3 4 5 »
